In What Order Should I Paint Room? - Painting - DIY Chatroom Home Improvement Forum
Old 09-02-2008, 05:26 PM   #1
In what order should I paint room?
Hi, I know ceiling goes 1st, then should I do trim? Since ceiling isn't yet dry I would assume its a bad idea to cut in ceiling. Can you guys tell me your painting formula, please be as detailed as possible ie Ceiling, tape walls paint trim, remove tape etc etc. Thanks.
vpopov81 is offline   Reply With Quote
Old 09-02-2008, 06:32 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
It varies by project and preference
New construction, occupied re-paint, un-occupied re-paint, spray, brush'n'roller, crown molding, trim new/re-paint no-paint stained trim, furniture in room, business, office, home....etc....etc....
Do not use tape on fresh (less than a few weeks old) paint
slickshift is offline   Reply With Quote
Old 09-02-2008, 08:09 PM   #3
painting tips
I always do the ceiling first, let it dry for a day or two before doing first coat on the walls, making a clean line at the ceiling, but not the perfect (ha!) line that comes with the second coat. (We're assuming you did all the needed wall repairs first -- and washed down the walls.) Our trim is stained or in the process of being stripped and then stained, so we always do that last or we take it off and it goes on last. When painting trim it's personal preference as to which you do first.
If you have a 100-year-old house, you probably have nice trim -- don't paint it if you can help it!
Anyway, then do final cuts in for ceiling (tape if needed) and second coat of paint. Hope this helps!
Allison1888 is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
How should I paint this room? LeroyFrick Painting 8 10-30-2007 05:09 PM
