What Nap Roller Should I Use For Primer? - Painting - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 12:43 PM   #1
Rewards Points: 1,062
Question
What nap roller should I use for primer?
And does it matter, in choosing the nap, what the sheen of paint will be used over the primer? E.g. if I do my bathroom in semi-gloss using 3/8" nap vs living room in flat with 1/2" nap, should I also prime the bathroom with 3/8" nap and the living room with 1/2" or it doesn't matter? the material i am painting is drywall (semigloss on greenboard, flat on regular, if it matters)
Old 04-21-2013, 04:32 PM   #2
Rewards Points: 5,974
I use 1/2" for most but it depends on what you are painting. Is it smooth, is it textured, how heavy is the texture? The sheen of the paint has nothing to do with the nap size.
The Following User Says Thank You to ToolSeeker For This Useful Post:
amakarevic (04-21-2013)
Old 04-21-2013, 04:36 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
1/2 for all
The Following 2 Users Say Thank You to chrisn For This Useful Post:
amakarevic (04-21-2013), princelake (04-21-2013)
Old 04-21-2013, 04:37 PM   #4
drywall, i thought that was a given, sorry.
i've been told that 3/8" is for semi-gloss, 1/4" for high gloss, 1/2" for flat
Old 04-21-2013, 04:39 PM   #5
Originally Posted by chrisn View Post
1/2 for all
i was told finer nap for more gloss but OK. thanks
Old 04-21-2013, 04:44 PM   #6
Rubbin walls since'79
Brushjockey's Avatar
It also has to do with the quality of the roller and technique.
1/2 with good in both can do just about anything.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 04-21-2013, 04:44 PM   #7
Look on the plastic the roller comes in 3/8 says for smooth surfaces, 1/2 I think says for semi rough, 3/4 says rough and on up none of them say any thing about the sheen.
Old 04-21-2013, 04:47 PM   #8
what category does drywall belong to?
Old 04-21-2013, 07:00 PM   #9
I use 1/2 for primers, flats, mattes, and eggshells (on full size rooms). I haven't put a 3/8 cover in flat in about 8-10 years. I would use 3/8 for mattes and eggshells in small area rooms, but not for the texture but the quantity the cover holds. I don't want a cover that will hold enough paint to paint one half of the room with a single dip. And though I haven't rolled semi-gloss on walls in I don't know how long, I would use a 3/8 if I couldn't dodge that bullet. 1/2" and up for textured walls regardless of sheen. Tool, they do spec certain covers for certain sheens.
Old 04-21-2013, 07:59 PM   #10
Not to my knowledge.
Unfinished drywall would be considered smooth but I would still use 1/2.
Old 04-21-2013, 08:08 PM   #11
For the Purdy Golden Eagle
Product Specifications:
Material: High Density Polyester (Knitted)
Paint Types: All Latex and Oil-Based Paints and Stains
Paint Finish: Flat, Eggshell & Satin Finishes
Surface Texture: Smooth to Extra-Rough Surfaces
Core Material: Polypropylene
Core: 1-1/2"
Sizes: 3/8", 1/2", 3/4", 1", 1-1/4"
Lengths: 3", 4", 7", 9", 18"
Usually says it somewhere on the cover too. Nothing I ever pay attention to anyway.
The Following User Says Thank You to jsheridan For This Useful Post:
ToolSeeker (04-21-2013)
Old 04-21-2013, 08:31 PM   #12
Question
for semigloss on drywall, would you use 3/8 or 1/2 ?
Old 04-21-2013, 08:48 PM   #13
If I was rolling a bathroom or other small sq area, I would use a 3/8. If I was rolling a larger area, long or high walls, God forbid, I would use 1/2. 3/8 wouldn't carry enough paint to move fast enough on long or high walls. On any kind of texture surface though you have to start at 1/2 to get the depth, regardless of area.
Old 04-21-2013, 08:56 PM   #14
Question
That's exactly what I am doing, a bathroom. And the speed is NOT an issue, perfection is. However, I have already done the first coat with 1/2" (as per some of the above suggestions). Do you think it will be better if I do the 2nd coat with 3/8"?
Old 04-22-2013, 03:49 AM   #15
How does it look? How was it working with what you used? If both OK, you'll be fine staying with what you have. It's not about speed, but control. A 3/8 cover holds less and in a smaller room it's just easier to control the amount of paint I'm working with, but it doesn't make it impossible. Just go a little easier on the amount you pick up each time.
Tags
paint , primer , roller
What am I Doing Wrong Here (Roller Marks, pics) dimswits Painting 13 08-01-2016 05:33 AM
Painting Technique Help RichardZ Painting 5 01-31-2013 05:12 PM
Wet Edge on Walls: How Far Per Roller Load? Twister Painting 10 11-23-2011 04:28 AM
Exterior Painting-Brush or Roller? Smokin Gun Painting 8 07-12-2011 04:02 AM
Flashing --> how does it occur and how to prevent it gramps416 Painting 5 05-26-2010 11:11 PM
