What Makes Up A Quality Hvlp Sprayer - Painting - DIY Chatroom Home Improvement Forum
Old 04-04-2012, 08:30 PM   #1
Stairguy
Millertyme's Avatar
Rewards Points: 508
What makes up a quality hvlp sprayer
Have used the cheap harbor freight guns. It sprayed ok for $15, but thought if I bought a better gun I would get better results. So I bought a $80 porter cable sprayer thinking I would get better results. To tell you the truth I saw no difference in the guns. I want a smoother finish. It does not seem to atomize properly no matter how I have it adjusted. In fact I usually have to use about 80lb of air just to get he paint to come out thick enough. The guns are clean, and I have thinned the oilbased primer. I see some really expensive guns on the Internet and was wondering what makes these guns any better than the ones I have. they all look the same as the ones I already have. Do they just have better finely tuned mechanics inside the gun?
Millertyme is offline   Reply With Quote
Old 04-04-2012, 08:37 PM   #2
Too Short? Cut it Again!
Nice tips on the ends to start. Not plastic ones. Consistent and constant air pressure not availed at $80 would top my list also.
I paid people to spray for me.
Old 04-04-2012, 10:09 PM   #3
Rewards Points: 258
The gun is only one part of the equation. The compressor or turbine is equally important. And finally the viscosity and type of material you’re using should be slightly thinner than that sent through a conventional system, and we’re not even talking airless. The HVLP I use is a $900 unit and there’s a good reason why it costs that much compared to a $150 system. If you want performance, changing guns is not the total answer. A good system is an investment not a week-end toy. If you want to make money with it, invest in a good system, otherwise expect something less than you would like. IMO
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 04-06-2012, 01:15 PM   #4
Drywall contractor
Rewards Points: 1,070
Spraygunn makes a good point. I've found that with all tools, you get what you pay for. I've bought a tool or two from China Freight for things I do on rare occasions. I don't expect them to last very long, but am pleasantly surprised on occasion and have been disappointed when they don't make it through the task at hand. They tools I use daily to make a living are definitely professional grade....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-10-2012, 09:52 AM   #5
Rewards Points: 394
Better HVLP units have an assortment of aircaps and projection sets (needles) which can be used for a variety of materials. As stated, you get what you pay for, but it depends how often you use the unit, and for what purpose.
Will22 is offline   Reply With Quote
kitchen sprayer troubleshooting jhustwit Plumbing 6 06-14-2010 01:46 AM
Bayer liquid weed killer & 2 Gallon flomaster pressure sprayer combo pack @ HD $10 whataboutj Landscaping & Lawn Care 25 05-13-2010 10:01 PM
Paint for HVLP sprayer Mike in Arkansas Painting 6 01-24-2010 04:44 PM
Need Advice on a Paint Sprayer HandyFrank Painting 15 01-09-2010 10:59 PM
Entry Door Quality -- Questions About Manufacturers I G Norant Carpentry 1 07-27-2006 09:05 PM
