What Kind Of Primer Do I Need - Painting - DIY Chatroom Home Improvement Forum
Old 01-25-2011, 03:50 PM   #1
what kind of primer do i need
my mobile home has textured wallpaper in the living room and where each drywall panel meets is a vertical trim piece from the floor to the ceiling. i want to remove these trim pieces and patch the panels together with drywall mud. but i also want to fill in the texture of the paper so its smooth. i need a primer than call be used over drywall mud and wallpaper. HELP!
sh417 is offline   Reply With Quote
Old 01-25-2011, 07:43 PM   #2
Gymschu's Avatar
Rewards Points: 658
KILZ original is the best primer for this application. It stinks to high heaven so you need plenty of ventilation. If you use a water-based primer on the wallpaper, the water will reactivate the adhesive and create giant bubbles that you will have to cut out and fill later. So, if you can tolerate the fumes of the KILZ, that's a good option, it sticks to everything and WON'T reactivate the wallpaper adhesive.
Old 01-26-2011, 07:03 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 310
kilz original iol will work( no other kilz product will) but this will do it also without as much smell
Old 02-02-2011, 01:20 AM   #4
Super Master Painter
Ole34's Avatar
do yourself a favor and try to pull a piece of that paper off ..............if it comes off easily then the last ting you want to do is paint over it..........i dont care what kind of primer you use.
Ole34 is offline   Reply With Quote
Old 02-08-2011, 03:54 PM   #5
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
Usually any type of primer with lead in it will do just fine.
how to remove popcorn
stoner529 is offline   Reply With Quote
Old 02-08-2011, 04:00 PM   #6
Rewards Points: 459
Are you sure it's drywall? Most mobile homes are made with a "Presentation Board" - a luan with a wall paper-like laminate. The reason that they use the batten strips vs. compound is because of the flex associated with not being sat on a foundation. You'll know if this is the case when you pull the battens - you'll see the staples holding the panels on.
If your mobile home is not on a foundation, you may want to re-evaluate the tape & compound idea.
Nick DIY is offline   Reply With Quote
PVA primer vs. Tinted primer? HandyBrad Painting 17 12-29-2010 07:59 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 10:33 PM
Painting Question jweiner Painting 23 12-23-2008 10:59 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 06:38 AM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 12:54 AM
