What Kind Of Paint To Use For A Fireplace Surround? - Painting - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 09:36 PM   #1
Rewards Points: 666
What kind of paint to use for a fireplace surround?
I want to paint the black fireplace surround, as pictured. Does anyone have advice on the best type of paint to use? Assuming that spray painting is the best option of application?
kennykenny is offline   Reply With Quote
Old 02-09-2012, 09:47 PM   #2
Rewards Points: 13,694
Why do you want to paint it?
That's a factory finish made to withstand the heat. Any other finish may or may not hold up.
You going to have to degrease it, sand it and use a high heat paint. Rustolium has some good ones.
Old 02-09-2012, 09:48 PM   #3
when i redid my fireplace i repainted the face of the fireplace with regular flat black stove paint worked great and its made for high heat applications. i also repainted the gold strips on the glass with a silver hammered metal paint.
Old 02-09-2012, 09:54 PM   #4
Rewards Points: 666
i just redid the tile around the opening and it has scratches on it.
Re:when i redid my fireplace i repainted the face of the fireplace with regular flat black stove paint worked great and its made for high heat applications. i also repainted the gold strips on the glass with a silver hammered metal paint.
Danny T: How did you apply the paint? Spray paint?
Old 02-10-2012, 10:49 AM   #5
yes spray paint i got at HD. i had already redid the tile also and wanted the front of the fireplace to look new also. i just masked off the tile and mantle and sprayed 2 coats. i covered the floor with a big drop cloth.
Old 02-10-2012, 11:57 AM   #6
Too Short? Cut it Again!
I would mask off and use rattle cans for such a small area. Adequate ventilation and extend the masking further than you think the paint would ever reach.
Given the potential heat? I would go to the auto parts store and pick a color of high heat engine/exhaust enamel you like as it will not discolor. If you just want black, you can get rattle cans of paint for barbecue grills in gloss and flat. It comes in some other limited colors as well.
I would scruff up the surface a bit with some steel wool or wet sand paper.
Check the expiration dates of spray paints if you buy from a box store. They are notorious for not rotating merchandise. Buy fresh stuff.
Old 02-10-2012, 03:25 PM   #7
BraniksPainting's Avatar
I agree with DannyT. I redid my fireplace and used a spray can of Black Stove paint as well. Though, I did not paint the surround. I painted the inside walls of the fireplace. You can buy it at most Box Stores or any place they sell fireplaces. If you are looking for a shiney finish, I'd stop at the automotive store and buy engine paint or brake caliper paint. It's the same thing.
BraniksPainting is offline   Reply With Quote
Old 02-11-2012, 08:53 AM   #8
Rewards Points: 666
Thanks for all of the advice. Where do you purchase the black stove paint? Is this at HD and/or Lowes as well?
Old 02-11-2012, 09:08 AM   #9
I know for sure my Lowe's has it.
Old 02-11-2012, 09:11 AM   #10
Lowes, Home Depot, any hardware store or lumber yard will have it.
Old 02-13-2012, 11:23 AM   #11
Rewards Points: 666
Is this the back stove paint that is being refered to?
http://www.homedepot.com/webapp/cata...&Ntpr=1&Ntpc=1
Old 02-14-2012, 11:06 AM   #12
that's the one i used
Old 02-14-2012, 11:34 AM   #13
Rewards Points: 666
About how many cans did it take for you to spray your fireplace? Is brushing it on an option or will it look better spraying? I am not the best at spraying? Would brushing leave paint brush marks?
Old 02-14-2012, 02:32 PM   #14
I bought one can and didn't even use the whole can. If you are painting the surround, I would try and spray it. It will leave a much nicer finish.
Old 02-15-2012, 01:16 PM   #15
i did 2 coats on the face and the sliding screens and still have half a can
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Painting Old House Smokin Gun Painting 36 07-05-2011 01:24 AM
Access Door Panels For Tiled Fireplace Surround Fire4Effect Tiling, ceramics, marble 0 09-07-2010 01:12 PM
Need some help with Fireplace base and surround bowanna03 Carpentry 4 03-14-2010 04:37 PM
