What Grit/tool To Use To Sand Drywall AFTER Primer - Painting - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 11:06 PM   #1
Rewards Points: 81
What grit/tool to use to sand drywall AFTER primer
I just finished my primer coat on my new drywall and its looking good so far. Howver, I did notice a lot or fuzzies and am going to sand the primer lightly before my color coats tomorrow. I have a few questions:
1.) What grit?
2.) What tool (i have several sponges, hand and stick snader)
3.LShould I just lightly sand all of it, or only where needed
Thanks,
Mike
shelzmike is offline   Reply With Quote
Old 02-25-2012, 11:19 PM   #2
long island, NY
what do you mean "fuzzies"? do you mean that the drywall's surface paper is getting fuzzy/worn down from sanding too much? might want to skim coat that before proceeding. I think sanding without doing that would only make the fuzzies worse.
Otherwise, I'd use a very fine grit and would only sand where needed. Use whatever tool you prefer... I love those sponge sanding blocks for small touch-ups like that.) clean it up with a tack cloth before painting. Also touch-up the primer where needed before progressing to the paint.
diy'er on LI is offline   Reply With Quote
Old 02-25-2012, 11:19 PM   #3
Rewards Points: 14,306
Sanding sponge would work fine. No harm in going over all of it. May find some runs you missed.
Old 02-25-2012, 11:50 PM   #4
Workaholic's Avatar
Rewards Points: 268
I would use to pole sand with 100-120 grit. Depending on what you mean by "fuzzies"
Sean
Workaholic is offline   Reply With Quote
Old 02-26-2012, 12:03 AM   #5
Rubbin walls since'79
Brushjockey's Avatar
I bet he means roller lint.
I would do like Work said- use a sanding pole if you have one, a hand sander would be next choice, sponge would be third. Lightly sand it all- shouldn't take to much to knock of the roller 'fuzzies" and other bumps.
Use a quality roller cover- and you won't have the fuzzies so much.
Don't wipe with commercial tack cloth- that was made for oil finishes and contains linseed oil which might cause adhesion probs with latex. What works really good and fast is a swiffer on its pole.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
jsheridan (02-26-2012)
Old 02-26-2012, 09:30 PM   #6
Rewards Points: 626
Using the correct primer you should not have any fuzziness that is what the primer was for. Let me guess you used something from a big box store? you can spend a few extra bucks and go to SWP and get the right stuff and then paint.
Nailbags is offline   Reply With Quote
Old 02-26-2012, 10:45 PM   #7
Rewards Points: 81
What I meant was the fuzzies that came from sanding the drywall ever so slightly too much (like around screws specifically). Where the paper was rought up a little bit.
And I am using SW Multipurpose Primer, which is great btw. I used a pole sander and wife used sponge and it worked beautifully. Thanks for the input.
Mike
Old 02-26-2012, 11:42 PM   #8
Rewards Points: 626
Well thank you for clearing things up. when you mud and tape that is when you sand. then prime and paint. sanding should be done prior to any form of paint going on.
Old 02-27-2012, 05:13 AM   #9
It's necessary/customary to sand all primed, previously bare substrates. In fact, the only coat that doesn't get some degree of sanding is the final one.
Old 02-27-2012, 08:44 AM   #10
Rewards Points: 81
I did sand after I taped and mudded. However, I also wanted to sand after priming because I read that not only should one do it, but it is the one step tha most beginners skip. Since I was a beginner I didnt want to skip it and I am glad that I didnt because it made all the difference in the world. Thanks again for the feedback!
Mike
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 11:48 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
