#1 |
What Grit should I start off with - paint/wood
I'm sanding/removing with a Rotary Sander paint/joint compound that is ontop of wood jambs. The goal is to bring it back to wood, then fill the indents with wood filler...prime and paint.
Due to expansion/contraction, the plywood jambs is transferring cracking through the mud/paint. How agressive should I start. 40/60 or 80 grit.... |
#2 |
it's easy to start w/ 80 and see how it goes. i bet you end up ripping it up w/ the 40, then tapering down a tad.
#3 |
I vote for 80 to start, also. If you get too aggressive to start, it takes more sanding to get out the scratches. Use a shop vac and a good respirator or similar to keep down the dust, especially if the house is pre-1978.....lead based paint.
#4 |
I bought inexpensive pvc fittings and matching flex tubing to match up the exhaust tubes my sanders to the shop vac.
As suggested start with finer grit and mind lead. I will also plug infrared strippers. Amazing tools for stripping layers of paint. Fast and safe. Expensive but you can rent. Or buy and sell instantly when done. Best approach to such projects I have ever encountered. Got good money for my well used one!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
I looked at those infared strippers. I'm sanding this with my Festool and Ceros system so dust is minimal.
And with a scraper, it does some off, so I won't need the grunt of the infared...which while effective, is slow. Not alot. Just about 7 Door Jambs, and 3 *window headers* -- top of basement window RO. |
| Display Modes | |
| compressor wants to start but won't | wetbar | HVAC | 13 | 06-17-2010 07:15 PM |
| Homelite weedeater won't start. Out of ideas. | Jasnall | Landscaping & Lawn Care | 7 | 06-03-2010 02:12 AM |
| Troy-Bilt 2-Cycle Gas Trimmer Will Not Start | g8tkeeper | Tools | 2 | 08-26-2009 09:26 AM |
| Troy-Bilt 2-Cycle Gas Trimmer Will Not Start | g8tkeeper | Landscaping & Lawn Care | 3 | 08-13-2009 11:58 AM |
| How to repair/clean centrifugal start switch | pointertopica | Electrical | 4 | 12-03-2008 08:05 PM |
