What Grit To Sand With? - Painting - DIY Chatroom Home Improvement Forum
Old 02-22-2008, 09:49 PM   #1
bofusmosby's Avatar
What Grit to Sand With?
I am doing a complete resoration of my house, and because there are so many layers of paint on the outside , and there is wide spread paint falure, I am removing all the old paint, exposing the bare wood. I am using 2 coats of oil-base primer, and 2 top-coats of Acrylic laytex. What is the finest grit sandpaper I should be sanding the wood with? I want a smooth finish, but I want to give the primer a good surface to gab on to.
Thank you for your advice!
bofusmosby is offline   Reply With Quote
Old 02-22-2008, 11:09 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Sanding after a full strip?
Well, it depends on what the siding/substrate actually is
And on how it's been stripped
slickshift is offline   Reply With Quote
Old 02-23-2008, 08:36 AM   #3
bofusmosby's Avatar
I am using the "paint shaver" to remove most of the paint. The corner-boards are pine, and the clap-boards are cypress or spruce(I think).
Old 02-23-2008, 08:19 PM   #4
slickshift's Avatar
Hmmm....well the specific primer manufacturer may have a specific grit suggestion, but mostly they want to make sure the surface is not smooth or "glazed"
You'll have to make somewhat of a judgment call when the time comes, but generally no finer than 180
150 is probably a good starting point, as you can go up (180) or down (120)
It will probably be somewhere in there though
It depends on what the shaver leaves you, and the overall condition of the wood
Old 02-23-2008, 08:30 PM   #5
bofusmosby's Avatar
Thank you for your advice. To be honest with you, I have been using 120 grit as the finest, thinking that any finer might make it a little too smooth for the primer to get a good bite on the wood.
As far as the "Paint-Shaver" goes, you have to be real careful, or it'l really gouge the wood. I have found it to be better to get most of the paint off, leaving a little, and getting that off with a random-orbital sander with 40 grit paper. Then go to 80,, and finally 120. Does this sound OK? If not, I'll just use another step with 180.
Old 02-23-2008, 09:51 PM   #6
slickshift's Avatar
Your instincts are probably correct for your project
I wouldn't step up unless you have issues
You must be doing a fair amount of material removal (comparatively) if you are using 40
An 80 then a 120 sounds about right if you need to start with a 40
Does the shaver leave any glazing (shiny spots)?
Or is the sanding mostly material removal and then smoothing a little?
Old 02-23-2008, 10:14 PM   #7
bofusmosby's Avatar
The shaver is actually rotating knifes, and you can adjust it to the amount of material you want to remove. Like everything else, there's a down side. It can remove a lot of wood very quickly, and mistakes do happen. I use Bondo to even up any "mistakes" I make. You can do a pretty good job if you're careful. However, there is an amount that the "shaver" can't reach, so there is the regular scrapeing and sanding that has to be done. There is also a sanding attachment, or assembly that sands it after the paint has been removed. All the paint and dust goes right to the vac. I would be having to remove a certain amount of wood anyway, because of the deteriation of the outer wood layer. If I try to paint right over the discolored wood, I believe it would peel in no time.
I guess it does OK, I had a local code enforcement officer saying he liked the way the new vynal siding looked on the house. He said it looked too good to be wood? What ever that means.
Thanks for the advice on the sanding. I have been doing it this way, but I figured if I was doing it wrong, I need to correct it now. Believe me, I'm no expert, and will never pretend to be one on this subject.
Old 02-23-2008, 10:33 PM   #8
slickshift's Avatar
If you've roughed up any smooth (glazed) spots, and it's not real rough (like rough enough to show the roughness through the primer), then you're just about right
If you start priming and the surface is still lumpy after that (test a spot first), then step up to the 150/180
Old 02-24-2008, 02:25 PM   #9
She'sapainter
If you are removing all of your exterior paint you are in for aaaa... job, I hurt just thinking about it.
However if the paint is built up and failing I'm going to assume it's been 17 to 20 years since it's last repaint. Which in that case I personally would start with a 60 to 80 grit to cut through the touch area's, then I would move to a smoother grit and so on.
There is also a tool called a power stripper But use with caution for it is a wood house and the power stripper is a heat stripper , you can tell when to stop using this tool in the area your working.
Also in your area's where you are unable to get the wood smooth you can use a product called ( last o merit) It's a waterproofing compound that you can get in different grades of applications brushable it the best for mared area's as long as you apply in one direction with as less strokes as possible best used after prim coat. We painter have been using it for years.
Have you thought about one coat of prim and 3 coats of finish paint? the finish paint is what is going to give you your protection.
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
Old 02-24-2008, 06:44 PM   #10
bofusmosby's Avatar
tverhoef, I haven't thought about 1 primer, and 3 topcoats, but I have been considering 2 primer and 3 topcoat. This is a huge house for one person to tackle. I've got all across the front downstairs (35') and now am started on the upstairs. I am doing a small section at a time, and was thinking about giving it one last topcoat when the entire front is complete.
Thank you for your feedback!
Old 02-25-2008, 07:09 AM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
tverhoer, I haven't thought about 1 primer, and 3 topcoats, but I have been considering 2 primer and 3 topcoat.
What is the reasoning for 2 coats of primer??
Old 02-25-2008, 08:27 AM   #12
bofusmosby's Avatar
1 coat of primer does not cover well, so I give it a light sanding, before the second coat. I guess my inexperience tells me if 1 coat does good, then a second coat will be that much better. I know that I might be wrong on this, but so far, I have had no problems. Does it actually cause problems putting on a second coat of primer?
Old 02-25-2008, 10:55 AM   #13
She'sapainter
One coat of primer should be sufficient, If your not ripping the primer. Primer is an under coat it is used as a sealer and a gripper for the paint it doesn't have a strong skin. where as the finish paint is made to with stand the elements it sort of encapsulates your house. this is your house and not mine,Good Luck
Just be careful that you don't put so much primer that it doesn't dry under the paint.
Old 02-25-2008, 06:44 PM   #14
bofusmosby's Avatar
When I put down a coat of primer, It usually is at least a week before I put the top-coat on(or the second coat of primer).
So in other words, there is no reason to put on 2 coats of primer? I guess that blows my thinking out of the water.
Thank you for the advice!
Old 02-25-2008, 08:00 PM   #15
She'sapainter
That is correct... if at one week you dont see any lifting then the primer has done its job..which would allow you to spend extra monies on more finish paint which is going to do all the real work.
Just keep in mind I live in CA and we normally don't have the wheather like most in th midwest and east coast.
Paint with a grit texture???? Sellncars Painting 3 09-24-2006 07:37 PM
