What Is Good Primer For Exterior Painting - Painting - DIY Chatroom Home Improvement Forum
Old 05-02-2014, 10:15 PM   #1
Post
What is good Primer for Exterior Painting
Hi, I am about to start exterior painting project for my house located in Tampa, Florida. First story are blocks and second wood, both stucco coating. I supply paint and chosen SW Emerald paint already but not primer yet. My contractor told me that they normally use SW Lox clear Primer but I 've heard that white color Zinsser 1-2-3 is one of the best.. My friend on the contrary recommended KILZ primer. The job starts this Monday and I need urgently make decision .. I don't have experience and don't have time to experiment with primers .. would greatly appreciate good advise.. like real coverage per sq. f, difference white vs clear etc., any changes in paint color when different colors primers used THANKS
Valerian is offline   Reply With Quote
Old 05-03-2014, 04:45 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
Does it actually need priming?
http://www.sherwin-williams.com/sher...ory2/index.jsp
chrisn is online now   Reply With Quote
Old 05-03-2014, 05:14 PM   #3
First of all thanks Chrisn for adding link that is very informative. As per Emerald (my choice of paint) it doesn't require primer according to the specs, though all contractors I spoke during interview for the job bidding said that they will apply primer. The price is the same regardless, so why not to prime ? Personally I found in my test with white primer that it makes visible if paint coat wasn't not applied evenly .. Also, I read on this forum that it's always good idea to apply primer It cost just about 100 $ for my house and I believe will provide extra layer of protection.. When Emerald is advertised as Primer and Paint in one, I think it's might be more commercial trick than reality.
Old 05-03-2014, 05:19 PM   #4
Gymschu's Avatar
Rewards Points: 192
You don't need any primer on previously painted surfaces unless there are bare spots after scraping and then you can "spot prime" those areas. You are getting one hell of a deal if the price is the same with or without primer. I can't imagine a legitimate painting contractor basically eating the cost of doing an extra coat by including the primer coat in his pricing. Seems suspicious to me.
The Following User Says Thank You to Gymschu For This Useful Post:
chrisn (05-04-2014)
Old 05-03-2014, 06:09 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
In general, clean exterior substrates in good condition don't require a primer before being coated with a quality paint like Emerald.
But one factor that can influence this is oxidation. Painted surfaces, and in particular painted stucco, often oxidate in the sun after a number of years. Especially flat paint, but enamels are susceptible to it too over longer periods of time.
The FL sun is brutal. Seems like there was a thread not too long ago about a peeling paint job we thought was caused by painting chalky surfaces.
The Loxon clear is designed to 'lock down' oxidized paint (chalk) and provide a good surface for topcoat adhesion. Other wise, paint can bond to the oxidation instead of the substrate and peel in big sheets like we have seen posted here before.
Bty, 123 is a great primer but it is not designed to adhere to chalk.
Jmayspaint is online now   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Gymschu (05-03-2014)
Old 05-03-2014, 08:26 PM   #6
Jmayspaint's Avatar
Rewards Points: 534
If the HO is providing the material, and the contractor providing a labor quote for specified number of coats, it would be feasible
for there to be little, if any, labor cost change caused by substitution of the primer. (Although changing specced products certainly can change labor cost in certain situations)
My personal thought would be use the Loxon conditioner, I don't see an advantage to 123 in this instance, ( provided there is no extensive peeling or water damage)
Old 05-03-2014, 11:34 PM   #7
I saw four contractors for estimation. All of them do primer regardless paint. Looks to me it's is standard in Florida.
The Following User Says Thank You to Valerian For This Useful Post:
Gymschu (05-04-2014)
Old 05-03-2014, 11:35 PM   #8
Probably I'll go with Loxon. Thanks
Old 05-03-2014, 11:38 PM   #9
Thanks. I'll go with Loxon then, It was recommended by my contractor anyway.
Old 05-04-2014, 05:20 PM   #10
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
I agree. I can't imagine a legitimate contractor priming a whole house for free basically.
housepaintingny is offline   Reply With Quote
Old 05-04-2014, 07:55 PM   #11
Rewards Points: 5,974
I agree with the Loxon. Down here a lot of times the primer is included in the bid.
Attempting to be a good DIY Chatroom member sore thumb General DIY Discussions 16 07-16-2013 12:16 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 12:48 PM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 07:29 AM
Bathroom paint/primer Termite Painting 11 07-02-2008 03:28 AM
