What Is A Good Paint Brush For Oil Based - Painting - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 01:49 PM   #1
What is a good paint brush for oil based
I am painting some cabinets and need to know what kind of brush and size is good for cabinets. Painting with oil based and want to have a smooth finish without brush strokes or at least a minimum. Any suggestions?
It appears a natural bristle is prefereed? What do you think?
cougarguy is offline   Reply With Quote
Old 02-04-2010, 03:27 PM   #2
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
These are sweet for oil. I'm thinking the 2 1/2 ox o angular would work pretty well. If you think the price is to high white china bristles are also pretty decent. Avoid the black bristle oil brushes, to stiff.
Kevin
http://www.thepaintstore.com/Purdy_O...air_p/2960.htm
Kevin M. is offline   Reply With Quote
Old 02-04-2010, 03:33 PM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
You will want a brush with white chiana bristles. I have tried many brands of brushes and there are a lot of good companys, but myself and my guys use and prfer Purdy brushes. Go to a quality paint store ie. Sherwin Williams and take a look at there purdy selection. Make sure you get one that has china bristles, the size will be up to you. What I might use and am use to using might not be the same size someone else is comfortable with ie. I generally use a 2.5 inch flat brush for most things, but someone else may be more comfortable with a smaller size or a sash brush, it will also depened on exactly what your going to be painting too.
housepaintingny is offline   Reply With Quote
Old 02-04-2010, 05:51 PM   #4
Too Short? Cut it Again!
I agree with the white china bristle and Purdy brand. If you take care of it, you will have it for quite awhile so if you can afford it, spend the money.
I use 2.5 or 3" angled sash brushes more than anything. I like having the angle to work with if needed and a flat brush doesn't offer the same control in some situations---for me anyhow. As mentioned, it is a matter of what a person is comfortable with.
Old 02-04-2010, 06:38 PM   #5
Thanks for suggestions. The white china brush works fine. however, I bought sponge rollers and they are incredible. I got a smooth finish and very easy to use. They are cheap, so I just discard after use. If you haven;t tried them on cabinets they are great. It is almost like a sprayed finish. there are no brush strokes.
Old 02-04-2010, 06:39 PM   #6
Rewards Points: 616
I find the Purdy white china brushes easy to clean and softer than the black china. As mentioned they will last a long time if you take care of them. I have some that have some age to them, yet they look almost new.
Old 02-04-2010, 06:48 PM   #7
Rewards Points: 616
We do occasionally use sponge rollers, but only in certain staining applications and they do work pretty well.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 08:38 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Any good tops for keeping paint from drying on the sides of the brush? Jim S. Painting 16 02-13-2009 03:18 PM
painting 1950's woodwork lizluther Painting 2 11-30-2008 10:28 PM
