What Finish Should I Use? - Painting - DIY Chatroom Home Improvement Forum
Old 10-15-2013, 06:13 PM   #1
Silverpointe's Avatar
What finish should I use?
Just finished priming this part of the kitchen wall. I've finally picked out a white but totally forgot to think about what choosing a finish. Semi-gloss? Gloss? Flat?
Silverpointe is offline   Reply With Quote
Old 10-15-2013, 06:17 PM   #2
ltd
Rewards Points: 536
semi gloss
ltd is offline   Reply With Quote
The Following 5 Users Say Thank You to ltd For This Useful Post:
747 (10-27-2013), Gymschu (10-15-2013), Live_Oak (10-16-2013), Silverpointe (10-15-2013), ToolSeeker (10-15-2013)
Old 10-16-2013, 04:29 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 128
The wood part or the wall?
wood, semi gloss
wall, eggshell
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (10-16-2013)
Old 10-16-2013, 06:27 AM   #4
747
registered
747's Avatar
Rewards Points: 534
wood, semi gloss
wall, eggshell
Yep. xxxxx
747 is offline   Reply With Quote
Old 10-16-2013, 08:55 AM   #5
Rewards Points: 5,974
Isn't it funny most of use assumed it was the wainscot.
Old 10-16-2013, 10:35 AM   #6
It did cross my mind when I wrote the original post that it wasn't clear which part of the wall I meant. I did mean the wood part. Is there something else to call it other than the "wood part"? It's kinda of similar to bead board except that the planks are much wider and it's definitely not wainscoting. Is this even a style or did the person who put it in just slap some boards up and decided it looked good?
Another question, which paint should I use? It's a BM color I've decided on. I've used BM Regal on walls and loved the texture but not what it did to my wallet. Used SW Pro Classic for trim. Had lots of brush marks but that could be technique. Thoughts?
Old 10-16-2013, 12:05 PM   #7
Rewards Points: 4,780
If you are putting on 1 coat, then do not go below quality of BM Regal, SW SuperPaint, etc. (It makes economic sense to spend more on paint in this case.) If you are putting on 2 coats, then a little less expensive paint can be used, but be careful you don't get into high spatter territory because then it's just not worth your time and trouble.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Silverpointe (10-17-2013)
Old 10-26-2013, 07:26 PM   #8
Painting Contractor CT
Rewards Points: 77
Semi-gloss on the wood and eggshell or matte on the walls..good luck!
KD PAINTING is offline   Reply With Quote
Old 10-26-2013, 07:57 PM   #9
Why do you say definitely not wainscot?
Screen & recoat hardwood with old, possibly waxed finish? TomServo Flooring 0 10-15-2010 05:09 PM
Paint and finish advice for desk addypearce Painting 0 09-03-2010 10:03 AM
Seeking a darker finish for wooden cabinets chibear1986 Painting 8 08-25-2010 12:15 AM
Remove stain and finish from oak furniture Rohey Carpentry 3 07-30-2010 08:03 PM
Finish failure SidingHell Off Topic 5 05-20-2010 03:00 PM
