What Equipment To Spray Cabots Solid Stain - Painting - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 09:34 AM   #1
Cold, Tired, and Hungry
What Equipment to Spray Cabots Solid Stain
What type of sprayer do I need to get to spray Cabots Solid Acrylic Stain? This stuff is as thick as paint and I have a lot of fence. Any suggestions?
Shaun_in_NC is offline   Reply With Quote
Old 10-17-2010, 12:31 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
At the minimum side a 3000psi sprayer that will pump at least .25gpm will work with a 515 tip, no thinning needed. We have several airless sprayers and have used an airless that small numerous times for cabot solid stain with no problems spraying it.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
hammerheart14 (10-17-2010)
Old 10-17-2010, 07:53 PM   #3
Rewards Points: 150
Good advice, housepaintinguy. Also, may I suggest to back brush your solid oil stain, after you spray a few boards at a time. The company recommends it AND from personal experience, it eliminates flashing. Otherwise, well, I hope you don't mind flashing. Be sure to apply ONE COAT ONLY, and to use a china (natural) bristle brush. If you over-apply this product, it will PEEL when it fails. If you do it right, it will just fade away.
hammerheart14 is offline   Reply With Quote
what solid stain is best? mpgumm Painting 28 03-19-2012 01:51 PM
Best Solid Stain for Siding...? thor Painting 7 08-25-2008 06:52 AM
Need advice on removing deck stain mwalt2 Painting 7 07-23-2008 06:51 AM
Solid Stain for cedar doors merlene Painting 2 05-28-2008 06:55 AM
Concrete Solid Stain vs Semi Transparent hgiljr Flooring 5 05-06-2008 06:00 PM
