Old 12-30-2012, 10:14 AM   #1
what to do with my short wall?
We are currently in the process of remodeling our office into a nursery. We have vaulted ceilings upstairs, but on one side the room it left a short wall. It is approx 4 ft high. With the vaulted ceilings, we are thinking we don't want to just paint the room all one color and would like to split it up. We have tossed around ideas of chair rail (just paint this wall the bottom color), paneling around the lower half of walls, or paint this wall and the two around it one color (it is not a rectangular room and there are some built in shelves that will break it up from the rest of the side walls)
So, what should I do with my short wall?
Thanks for any advice!
jboyd229 is offline   Reply With Quote
Old 12-30-2012, 10:17 AM   #2
so, what is your question ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 12-30-2012, 10:20 AM   #3
What do I do with my short wall?
Old 12-30-2012, 10:23 AM   #4
pro handyman's Avatar
Your over thinking it just paint the same color as walls and enjoy it. Congrats on the baby.
pro handyman is offline   Reply With Quote
Old 12-30-2012, 10:42 AM   #5
Rubbin walls since'79
Brushjockey's Avatar
If the surface is completely vertical- call it wall. the angles and ceiling - paint with a ceiling color.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is online now   Reply With Quote
Old 12-30-2012, 11:33 AM   #6
Metal Roofing
If your set on not just painting it, you may get some ideas from:
http://www.houzz.com/nursery-ideas
AndyWRS is offline   Reply With Quote
Old 12-30-2012, 11:42 AM   #7
Bill Kearney
Start by painting it the ceiling color. If you like it then you're done. Starting with the darker wall color would make for more work trying to cover it with white later. Me, I'd go with the ceiling color as a darker color on that slope might make the room look smaller than it already is.
wkearney99 is offline   Reply With Quote
Old 12-31-2012, 10:53 AM   #8
Paint the wall the same as the rest of the wall then add some decals of Disney or mother goose creatures for accent.
Old 12-31-2012, 03:49 PM   #9
Stuck in the 70's
Blondesense's Avatar
That slanted wall limits the useable space. I'd think about some built in cabinets or shelves to maximize use and storage.
Old 01-17-2013, 03:39 PM   #10
I found some good decals at bgdecals.com
craftymom07 is offline   Reply With Quote
Old 01-17-2013, 04:05 PM   #11
Newbie Bill
I would paint the short wall the same colour as all the other walls. Perhaps you can even do wainscotting on that wall and run it around the room at that level.
I would paint the angled wall a sky blue with some large clouds.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Tags
4 ft, nursery, short wall
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
How to calculate total glazing allowed in a wall? dalepres Building & Construction 3 04-22-2011 01:28 AM
Wall construction for insulation support WillK Building & Construction 3 12-09-2010 02:55 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
