What To Do First..flooring? - Painting - DIY Chatroom Home Improvement Forum
Old 08-04-2006, 11:56 AM   #1
what to do first..flooring?
We are finishing our basement and I am wondering in what order we should proceed with flooring. We are putting tile in the bathroom, putting laminate in the office,carpet throughout the livingroom/hallway and guest room. We are currently in the tape and texture stage and the will be painting. We are very new to all of this any advice would be helpful!!
JenM is offline   Reply With Quote
Old 08-04-2006, 06:24 PM   #2
I would put the tile down first.
Then put down the laminate.
Then finish with the carpet.
The tile and laminate may create dust during install that you do not want to get into the carpet.
redline is offline   Reply With Quote
Old 08-04-2006, 07:42 PM   #3
Pro Painter
AAPaint's Avatar
Caulk, putty, prime and do a first coat. Then put your flooring down and install all of your quarter round. Once this is done handle the finish coats. Flooring installs rough up the walls and trim 99% of the time. You may find you have to do some more puttying/sanding once the flooring is down before doing your final coat. Carpet is notorious for tearing up the baseboards when installed. Tile grout is another one. This is how most new homes are done in my area.
AAPaint is offline   Reply With Quote
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 01:04 PM
Chlorine Resistant Flooring for Bathroom herbolaryo Flooring 7 05-22-2007 09:05 PM
Hallway Flooring jay1000 Flooring 3 05-30-2006 06:04 PM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 09:08 AM
IAQ and flooring. Briefly. Benhamcarpetguy Flooring 12 03-24-2005 08:53 PM
