What To Do After Patching Bathroom Walls? - Painting - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 03:30 PM   #1
What to do After Patching Bathroom Walls?
I have just scraped, patched and sanded areas on bathroom wall that were peeling. I had used BM dove white latex paint. What is my next course of action? Should I just prime the spots I fixed with a latex primer and then paint or should I paint the entire bathroom wall with latex primer or another type of primer? I was going to use perma white but I have read it really has an odor. Is there anything else I can use in this area?
chipster7 is offline   Reply With Quote
Old 11-25-2011, 03:43 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Chipster- Read the two threads on damaged walls below- that might help
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-25-2011, 03:55 PM   #3
Did read the 2 posts as suggested. My question is should i use a pigmented primer like BINS before applying perma white or can I use a good latex primer before applying perma white? Does anyone know if perma white really has a strong odor to it? Thanks
Old 11-25-2011, 04:22 PM   #4
BIN is a pigmented shellac- way overkill for your needs.
If you are looking for a good low odor primer- i suggest Zinsser Zero ( if you can find it- Menards carries it around me), or Zinsser Smart Prime.
There are many good choices in a low odor paint for a bath. I would suggest it be an eggshell finish though.
Ben Moore makes Regal Select- I wouldn't hesitate to use that.
Perma white is a fairly good paint- If I remember right it does have an ammonia type smell. Not uncommon- lots of primers also have that. But paint is changing- and so are the options.
Old 11-25-2011, 06:42 PM   #5
Thanks Brushjockey.
Bathroom walls: hardi or green board? jelly Tiling, ceramics, marble 7 07-29-2011 10:27 PM
bathroom walls sheilagirl Painting 7 03-27-2011 05:42 PM
Bathroom Walls and Ceiling Become Cracked and Hazy ChantillyScott Painting 2 03-02-2010 01:20 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Bathroom Ceiling and Walls. Drywall ok? atilla137 Building & Construction 11 10-26-2006 03:32 PM
