What Is The Correct Order To Paint - Painting - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 10:29 AM   #1
What is the correct order to paint
I am about to start my painting of my living room. I would once and for all like to know from the pro's what the order they use when painting a room that needs ceiling, walls, baseboard, and door moldings painted. What are the sheen levels that they use for each area
stevenson66 is offline   Reply With Quote
Old 11-18-2010, 01:14 PM   #2
40+yrs Paint Trades
Painters start at the top. In order, ceiling, walls, windows and doors, baseboards last.
hoz49 is offline   Reply With Quote
Old 11-18-2010, 03:23 PM   #3
Rewards Points: 526
We have always done ceilings, casings, baseboards, walls. We have found it easier and better to paint baseboards, tape them, then do walls. Easy straight lines and very fast. Everyone has their own preferences.
Windows is offline   Reply With Quote
Old 11-18-2010, 04:45 PM   #4
40+yrs Paint Trades
Yeah, it's how you were trained. I knew a painter who was in business 20+ years who painted door and window frames before painting the walls because he couldn't cut a straight line down the trim and it was easier to hide by cutting the flat wall into the frames.
The only time I mask the base is if it isn't being painted. Otherwise paint the walls and then the baseboards.
Old 11-18-2010, 07:35 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
We usually sand the walls and patch any holes. We then paint the ceilings. Then we sand and prime any patched areas. The we paint the sides of casings and windows since 9 times out of ten it is easier to cut the wall to the casings. Then we paint the walls and then the trim.
Old 11-19-2010, 12:59 PM   #6
Do work
Rewards Points: 81
I think everyone will agree that the ceiling is first. After that it could go either way. Whatever works best for you. I like to do the trim last.
liquidvw is offline   Reply With Quote
Old 11-20-2010, 05:49 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
I agree
Old 11-20-2010, 08:32 AM   #8
Rewards Points: 101
I always paint the ceiling first, then I do all the window and door trim, then walls and baseboard last. Ig I've found this to be the most efficient way to do the job.
JMDPainting is offline   Reply With Quote
latex paint over oil-based = peeling paint! help! ImaDIYnewbie Painting 5 09-20-2010 04:48 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
Exterior Paint Prep Order utdel Painting 2 06-24-2006 01:56 PM
