What Is Chalky Residue? - Painting - DIY Chatroom Home Improvement Forum
Old 11-05-2013, 06:33 PM   #1
Rewards Points: 2,038
what is chalky residue?
should have posted a before and after photo. Too late.
When I bought this house last yr I could tell the double garage door had been dark brown at one time. (white inside) When I got the house the door was orange.
I've smudged the door and the orange came right off. Today using only water and a rag I washed 90% of the chalky orange stuff off. The door looks 100% better.
It wasn't quite rust, as the surface under the orange seemed fairly decent. So what was the chalky orange?
I'm thinking of using TSP to clean it even better. I don't have time to paint it now. The surface isn't smooth, but a deep wavy grain in the ? aluminum or whatever it's made of, so I'll probably have to use a brush when I do paint it.
thanks
Startingover is offline   Reply With Quote
Old 11-05-2013, 06:48 PM   #2
Rewards Points: 12,794
http://www.house-painting-info.com/chalking-paint.html
No need to use a brush except for any missed details
I've even used a foam roller and it can out perfectly smooth.
Sherwin Williams Super paint works well for this job.
Startingover (11-05-2013)
Old 11-05-2013, 07:03 PM   #3
thanks Joe.
No doubt this Fla. sun attributed to it. Guess I'm better off with the chalk than peeling according to your link.
Would Gardz be a good primer?
Old 11-05-2013, 07:07 PM   #4
Unless your changing the color drastically or there's missing coating there's no need to prime it.
Old 11-05-2013, 07:28 PM   #5
It's probably the darkest brown color possible now. When I paint it I want a lighter color, that will blend in with the brick, a medium beige or medium tan.
Is that considered a drastic change?
thanks
Old 11-05-2013, 07:36 PM   #6
Two coats of Super paint should be fine.
If you still want to prime it I'd just use Zinsser 123 and have them tint it to 50% of the color your going for.
Old 11-05-2013, 08:59 PM   #7
Faron79's Avatar
Rewards Points: 260
Yep-
Chalking paint is considered an "unsound" surface, & therefore must be washed-off, until "no chalking" remains obviously!
A garage-door takes a beating in the sun. No matter how good the final paint choice is, I'd prime it!!!
Faron
Faron79 is offline   Reply With Quote
The Following 2 Users Say Thank You to Faron79 For This Useful Post:
Startingover (11-06-2013), Will22 (11-08-2013)
Old 11-05-2013, 09:06 PM   #8
Jmayspaint's Avatar
Rewards Points: 534
It sounds like the orange residue was extremely oxidized brown paint. Cheap paint completely broken down by the elements and faded out to the point that it looked orange.
Joe is right, couple coats of paint would do the trick. It's fine to prime with 123 or something, but IME latex will bond great to clean aluminum.
Just make sure you have removed ALL the oxidation, it sounds like you got it pretty clean.
Jmayspaint is online now   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Old 11-06-2013, 07:33 AM   #9
really appreciate the help.
Wallpaper Residue mentalcase Painting 9 09-03-2012 06:22 PM
Tile over concrete with glue residue ebitler Flooring 6 02-01-2012 04:59 PM
painting and wallpaper residue jayoshi Painting 1 09-13-2009 06:03 PM
how to remove mortar glue residue on slate tiles aggiejess7 Flooring 5 05-13-2009 05:00 PM
Removal of residue after scraping popcorn ceilings? jdwilson Remodeling 2 09-15-2008 11:55 AM
