What Is This Board ? - Painting - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 09:28 AM   #1
Rewards Points: 226
what is this board ?
my garage was built in 09. they used a white strand board, that has a wood grain on it. what is this, and how should i paint it ? and any other issues i may have with it ?
Fix'n it is online now   Reply With Quote
Old 06-09-2013, 10:06 AM   #2
Roofmaster
Rewards Points: 2,172
WIth that many posts, I would have thought you would know the value of Photos?
Old 06-09-2013, 10:09 AM   #3
Rewards Points: 226
i figured this was an easy one.
Old 06-09-2013, 10:12 AM   #4
Rewards Points: 13,300
Ok so what's strand board?
Masonite, Smart side, Cement siding like James Hardee ECT.?
Old 06-09-2013, 10:15 AM   #5
Rewards Points: 226
a couple of scraps.
Old 06-09-2013, 10:16 AM   #6
Rewards Points: 226
OSB. i am assuming its primed, but idk.
Old 06-09-2013, 10:20 AM   #7
DIY staff
Rewards Points: 7,174
With that product---prime and paint all cuts before installing--
I'll leave the painting part to a more experienced painter---
Old 06-09-2013, 10:32 AM   #8
Rewards Points: 226
this is it installed. as you can see, the screws are still visible. i am going to paint this garage, someday = after i determine what color the house is going to be. in the mean time, i want to paint the trim, the same color as my new house windows.
Old 06-09-2013, 10:35 AM   #9
Rewards Points: 226
ooooops
oh, on a side note. the garage door. its a regular metal door. would it be a bad idea to paint it ? with what ?
Old 06-09-2013, 11:07 AM   #10
DIY staff
Yes--Paint the new work to protect it---garage door also if you wish--
One thing many folks do not realize-----primer will not protect the work from the elements----
Primers only job is to provide a good bonding surface for paint.
The nature of that allows water to penetrate and degrade the surface below---so get some paint on that primed wood real soon.
Old 06-09-2013, 11:14 AM   #11
Rewards Points: 226
ok. i think i am going to get on this.
i'm looking into SUPERPAINT, or DURATION. idk which yet. for the metal doors.
Old 06-09-2013, 12:30 PM   #12
Jmayspaint's Avatar
Rewards Points: 534
The weak point for that kind of board is the cut ends. They tend to soak up moisture and expand. The way the facia in the pic is installed, with no drip edge or guttering, is going to make it particularly vulnerable to moisture.
In addition to painting, I would caulk all the cracks to help keep water out. I even like to put a thin smear of caulk on the exposed board ends to seal them up even better.
If your not going to put up gutters, installing a drip edge would greatly improve the life of the facia board.
Jmayspaint is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Fix'n it (06-09-2013), oh'mike (06-09-2013)
Old 06-09-2013, 08:36 PM   #13
Rewards Points: 226
i do want to put gutters, but idk when. some day i would like to build out, idk what its call. but some kind of roof to extend out a couple feet over the doors all across the front.
Old 06-09-2013, 08:52 PM   #14
DIY staff
Google 'drip edge shingle roof' for a picture of the missing drip edge under the lip of the shingles--this will help keep water from damaging the new facia.
Old 06-09-2013, 09:20 PM   #15
Rewards Points: 226
i just looked at the shingles. they overhang about 1 1/2". would this not work as a drip edge ?
also. what is it that i am describing above ? about the roof extension thing
New control board or fix it? Bobeht HVAC 26 01-18-2012 04:03 PM
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-18-2012 12:46 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 02:16 PM
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 04:22 PM
Ridge board enough? runningforyou Roofing/Siding 9 08-13-2008 08:43 PM
