Old 05-09-2011, 09:23 PM   #1
What is the best way to strip this kind of siding?
See the image below:
I've seen the Paint Stripper Pro and it seems to work wonders, but I can tell that it would be ineffective on the beveled part of this siding.
Is a normal hand paint stripping tool the best thing to use? Chemicals? Heat guns? How difficult is it to sand this area as well?
Thanks for your help.
Clemsig07 is offline   Reply With Quote
Old 05-10-2011, 06:28 AM   #2
old guy contractor
tcleve4911's Avatar
It's referred to as Novelty Siding. Commonly made from pine as a sheathing/siding for sheds and camps.
Are you stripping it to stain or scraping for a paint prep?
tcleve4911 is offline   Reply With Quote
Old 05-10-2011, 06:55 AM   #3
Are you calling my house a shed??? Just kidding.
There must have been a good deal on this style 70 years ago, because it's what's on most houses in my area.
I'm planning on scraping and repainting. Since you seem to imply that the degree of paint removal depends on the style of finished desired, do I only need to remove the loose, flaky paint if I am repainting? I was wanting to remove as much paint as possible to ensure that my paint job would last as long as possible.
Thanks.
Old 05-10-2011, 07:01 AM   #4
old guy contractor
tcleve4911's Avatar
Just remove all the flaky paint and spot prime with an oil based primer.
You don't need to get ALL the paint off - only the areas that have lost their adhesion.
Good luck with the shed.....
Old 05-10-2011, 04:12 PM   #5
sdsester's Avatar
Towards the end, I bought an infrared stripper and it is an amazingly tool. Rent a good one and good sharp scraping tools, including one contoured to that groove, and this will go fast.
sdsester is offline   Reply With Quote
Old 05-16-2012, 07:02 AM   #6
SDSESTER: I have the same issue. I've had trouble locating a scraper thatt is "contoured to that groove". Could you make a recommendation of a tool or supplier? Thanks!
Dordrecht is offline   Reply With Quote
Old 05-16-2012, 09:37 AM   #7
sdsester's Avatar
Both Alway and Hyde make contour scraper sets. Small set should do. It has six two sided blades so 12 shapes for both interior grooves and external corners. Guessing $15 retail? Try amazon if your paint store does not have them.
I also have a Dremel contour sander I got in a parking lot sale for $10. Think they retail for $60? It is cute but worth no more than $10.
Old 05-16-2012, 06:01 PM   #8
paper hanger and painter
chrisn's Avatar
Here I thought you were alive all this time
Old 05-16-2012, 09:58 PM   #9
sdsester's Avatar
Funny how things have changed completely around. Here is the pendant I used to wear. Now I fear painters.
Old 05-19-2012, 06:50 AM   #10
Thanks sdsester. I ordered the Hyde yesterday: http://amzn.com/B000W65L7E
Masonite Siding Replacement kennykenny Remodeling 2 07-20-2010 05:52 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 01:32 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
