There must have been a good deal on this style 70 years ago, because it's what's on most houses in my area.
I'm planning on scraping and repainting. Since you seem to imply that the degree of paint removal depends on the style of finished desired, do I only need to remove the loose, flaky paint if I am repainting? I was wanting to remove as much paint as possible to ensure that my paint job would last as long as possible.
Just remove all the flaky paint and spot prime with an oil based primer.
You don't need to get ALL the paint off - only the areas that have lost their adhesion.
Towards the end, I bought an infrared stripper and it is an amazingly tool. Rent a good one and good sharp scraping tools, including one contoured to that groove, and this will go fast.
SDSESTER: I have the same issue. I've had trouble locating a scraper thatt is "contoured to that groove". Could you make a recommendation of a tool or supplier? Thanks!
Both Alway and Hyde make contour scraper sets. Small set should do. It has six two sided blades so 12 shapes for both interior grooves and external corners. Guessing $15 retail? Try amazon if your paint store does not have them.
I also have a Dremel contour sander I got in a parking lot sale for $10. Think they retail for $60? It is cute but worth no more than $10.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
