Old 03-12-2009, 07:39 AM   #1
What is the best way to paint a textured Ceiling?
Hi everyone.
What is the best way to paint a textured Ceiling? Meaning what type of Paint/Roller should I use? Do I need to prime first?
Here is an example of the textured ceiling I have:
(I had to seal up some louvres with spray foam insulation, then patch it up with drywall)
So I guess I may as well ask also, based on that image, is there a way I can fix that patch to match the rest of the ceiling? Its not a major problem if I can't, but would be nice . What type of material would I need?
Thanks in advance to any suggestions
earthad1 is offline   Reply With Quote
Old 03-12-2009, 09:18 AM   #2
I would scrape that patch down level with the ceiling. Then apply joint compound and swirl with a whiskbroom. As far as painting ceiling just use a 1/2 nap roller cover made for latex paint.
waynech is offline   Reply With Quote
Old 03-12-2009, 11:54 AM   #3
Remodeling Contractor
scraping this will pull it from the patch. Use a drywall rasp and patch with paper tape first. Final coat can be applied a little wet and thicker so you can texture lightly with a wisk broom as suggested.
Old 03-12-2009, 02:23 PM   #4
Matthewt1970's Avatar
I would scrape that down as well. Looks like it will stick out quite a bit after painting. Ater you scrape the surface of it off, that spot will drink the paint, so if you can, get a can of spray Bin and spray it a couple times before you paint.
Old 03-13-2009, 07:29 AM   #5
Thanks for the suggestions on sealing up those louvres....I'll try what is suggested. Thanks again.
So is there a ceiling paint brand out there that will make this job easier ?
Old 03-13-2009, 11:45 AM   #6
Old 03-13-2009, 01:10 PM   #7
Originally Posted by Matthewt1970 View Post
Cool, I think that's the one many people on here have been recommending, based on the threads I've been reading on here so I think I'll be going with this one... Thanks again...
Old 03-13-2009, 05:37 PM   #8
I love the stuff. Splatter resistant, goes on really nice and covers surprisingly well. I always think that there is no way it will cover some ceilings and I Rarely have to give a ceiling a second coat. Very Rarely. Also, it comes in 2 gallon versions if you think you might use more in the near future it will save you some money.
Old 03-18-2009, 09:14 AM   #9
Awesome! yea, I'm planning on painting all the ceilings eventually, so getting it in 2 Gallons is well worth it...
Thanks again
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
how do I remove textured paint without taking whole ceiling down johnsuchow Painting 5 09-09-2008 10:42 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
