What is the best way to paint a textured Ceiling?
Hi everyone.
What is the best way to paint a textured Ceiling? Meaning what type of Paint/Roller should I use? Do I need to prime first? Here is an example of the textured ceiling I have: http://i13.photobucket.com/albums/a2...2/IMG_1692.jpg (I had to seal up some louvres with spray foam insulation, then patch it up with drywall) So I guess I may as well ask also, based on that image, is there a way I can fix that patch to match the rest of the ceiling? Its not a major problem if I can't, but would be nice :). What type of material would I need? Thanks in advance to any suggestions :thumbup: |
I would scrape that patch down level with the ceiling. Then apply joint compound and swirl with a whiskbroom. As far as painting ceiling just use a 1/2 nap roller cover made for latex paint.
scraping this will pull it from the patch. Use a drywall rasp and patch with paper tape first. Final coat can be applied a little wet and thicker so you can texture lightly with a wisk broom as suggested.
I would scrape that down as well. Looks like it will stick out quite a bit after painting. Ater you scrape the surface of it off, that spot will drink the paint, so if you can, get a can of spray Bin and spray it a couple times before you paint.
Thanks for the suggestions on sealing up those louvres....I'll try what is suggested. Thanks again.
:) So is there a ceiling paint brand out there that will make this job easier ? |
:thumbsup: |
I love the stuff. Splatter resistant, goes on really nice and covers surprisingly well. I always think that there is no way it will cover some ceilings and I Rarely have to give a ceiling a second coat. Very Rarely. Also, it comes in 2 gallon versions if you think you might use more in the near future it will save you some money.
Thanks again :thumbsup: |
| All times are GMT -4. The time now is 08:40 AM. |
