What Is The Best Type And Size Brush For Exterior Stain? - Painting - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 09:03 AM   #1
What is the best type and size brush for exterior stain?
I need to know what type of brush to buy to apply Zar exterior solid stain onto smooth surface cedar siding.
I see brsitle, china brsitle, nylon, comination of bristle and nylon brushes being sold.
What is the best type of bruuh for this exterior stain that is 85% water and 15% oil?
Should I buy a brush that is rated professional painter's grade which is
thicker (more bristles) and also has longer bristles?
Any brand in particular?
The boards I am coating are a v-groove style and are 5" wide.
What width is best for this application?
jodebg is offline   Reply With Quote
Old 05-14-2013, 11:21 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Personally I use a latex 4" brush. I just never like the feel that the oil brush has.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 05-14-2013, 12:00 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
Don't use a natural bristle brush. Even though ZAR is a oil modified stain, you wash first with water then clean with thinner. Bristle brush and water don't mix well.
Jmayspaint is online now   Reply With Quote
Old 05-14-2013, 01:36 PM   #4
cdaniels's Avatar
I use a 3 inch nylon brush.High quality of course.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 05-14-2013, 03:11 PM   #5
Rewards Points: 256
Chinex 3"
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 05-14-2013, 03:49 PM   #6
Too Short? Cut it Again!
I would use a synthetic bristle brush of quality. Purdy and Wooster were my fave brands. 4" brush should work nicely but hold it in your hand and imagine what it will weigh loaded with paint. Don't get something that will be so heavy you need wrist surgery after using it!
You might think about using a thick nap roller in conjunction with a brush. Roll what you can then chase it with your brush making sure to get stain to the edges and up under the siding.
service entrance cable type & size Chuck S Electrical 5 01-08-2011 11:14 PM
Size of Wire & type of wire agman Electrical 6 11-10-2009 09:13 PM
What size and type of nails to use keviadams General DIY Discussions 2 09-28-2009 01:25 PM
Nail size and Type ????? mjkpainting Carpentry 7 11-21-2008 03:06 AM
What type / size screws for subloor project... scheenstra Building & Construction 1 05-17-2008 09:22 PM
