#1 |
What is the best reasonably priced zero VOC paint?
I've already ordered my paint but what would the pros rate as the best reasonably priced zero VOC paint for the other folks on the forum?
Essentially, what's the "best bang for the buck"? |
#2 |
Rubbin walls since'79
So far I am not impressed with any Zero voc paint. Zinnser makes a zero primer, called "Zero" that is pretty decent.
I use BM Regal Select- a very low voc paint.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS |
#3 |
Oh, and anyone other than Ben Moore who puts tint into their paint, is using a glycol based tint- and adding VOCs. BM atm is the only one with a 0 voc tint- the gennex tints.
#4 |
Painting Company, NY
Sherwin williams has changed over to a o VOC tint system too.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
I didn't know that - but I knew they had to do it to keep up.
What lines do they use it in?
#6 |
I believe they use it in all of there lines. I have used a few differant lines from them lately and they have used the o voc tint system.
#7 |
The zero voc tints at SW is not nationwide yet.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 |
paper hanger and painter
What is the best reasonably priced zero VOC paint?I am sure that's because they cannot afford it ![]() ![]()
#9 |
Doer of Many Things
P&L and Davis will likely switch over in the near future as well. Evonik has had a zero VOC tint system out for quite a while now. It does not require the massive investment the Ben Moore system does either. The tints work fine in a standard tint machine so long as it has sealing tips. It's also a direct pour over into the existing system at this point.
If you live on the mid-eastern side of the US I'd recommend Davis Perfection. Zero VOC, Ceramic finish, with Microban. Starts around $30 a gallon.
| Display Modes | |
| cheap paint in bathroom got mold? | mayhem69 | Painting | 12 | 05-06-2012 05:46 PM |
| Oil based paint over Latex? No need for Primer? | Jasonuncloned | Painting | 2 | 10-20-2010 11:33 PM |
| So many questions where to start?!?!(NEWBIE) | painter84 | Painting | 5 | 09-15-2008 01:50 PM |
| Paint will not stick in Bathroom! | SGTHetland | Painting | 9 | 08-18-2008 12:04 AM |
