What Is The Best Paint In The World? - Painting - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 05:08 AM   #1
What is the best paint in the world?
Majid is offline   Reply With Quote
Old 02-02-2009, 06:32 AM   #2
ccarlisle's Avatar
Define "best"...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 02-02-2009, 06:38 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 622
If you believe this kind of stuff
http://www.consumersearch.com/interior-paint
Old 02-02-2009, 08:15 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,.. That would be the 1 Best suited to your particular Application....
Old 02-02-2009, 08:32 AM   #5
The guy behind the counter at HD told me BEHR was.
jerryh3 is offline   Reply With Quote
Old 02-02-2009, 11:37 AM   #6
Carpenter
DecksEtc's Avatar
Of course he did
Benjamin Moore and SW are two of the best for interior.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 02-03-2009, 04:57 PM   #7
Home Improvement Guy
ron schenker's Avatar
I get excellent results with dollar store paint.
Just kidding
ron schenker is offline   Reply With Quote
Old 02-03-2009, 05:10 PM   #8
Remodeling Contractor
The best is only available from Industrial Suppliers. But for home owners painting a wall I would say C2 is the best out there right now.
Old 02-03-2009, 06:40 PM   #9
Rewards Points: 2,906
Actually, the best paints in the world are probably those used to paint commercial airplanes.
Those paints have to be VERY colourfast, they can't fade from exposure to UV light from the Sun, and above the clouds where most planes spend much of their time, there isn't a lot of shade.
They have to tolerate rapid changes in temperature, like on a flight from Washington, up to 30,000 feet where it's -35 deg. F, land in Honolulu where it's 90 deg. F and not crack or peel.
And, they have to adhere well to the substrate. I don't know of any house paint that would stay stuck to the walls inside a wind tunnel at 700 mph air speed.
Automotive spray paints will cost from $150 to $400 for a quart, and I expect the paints they use on airplanes are at least that much.
Now you know why they use different binders, pigments and additives in house paints to keep the price down to $35 per gallon.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
The Following User Says Thank You to Nestor_Kelebay For This Useful Post:
Nailbags (06-23-2012)
Old 02-03-2009, 07:49 PM   #10
It all depends on what you are looking for! That is a broad question.
mbowers is offline   Reply With Quote
Old 02-04-2009, 05:31 PM   #11
Tired, Cold, and Damp
slickshift's Avatar
There is none
The Best Paint depends on your application, financial, quality, availability, and idiosyncratic technique requirements and desires
If one paint met everyone's needs, soon (ie: by now) there would be no others
slickshift is offline   Reply With Quote
Old 03-12-2009, 08:07 AM   #12
Behr
I've never had a problem with Behr. I used it in every room in my house with the exception of the kitchen. I actually like the Behr semi-gloss for trim better than the SW cashmere. Plus it's about 10-15 dollars cheaper. I think it's pretty decent paint regardless of what some contractors may think.
mjarema414 is offline   Reply With Quote
Old 03-12-2009, 08:16 AM   #13
One and one person only. You must not understand what makes a quality paint. Do not post when you have no idea as to what you are talking about. This is one of the worst paints on the market.
Just to learn by trial by some C2 and make a comparison to your Behr. One coat. Scrub clean after drying to test durability. Then appreciate a real paint quality.
Old 03-12-2009, 08:40 AM   #14
the Musigician
DangerMouse's Avatar
ship paint, military grade.
DM
Old 03-12-2009, 09:15 AM   #15
DM
you didn't even finish siding your house and you have time to paint ships?
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
