#1 |
What is the best paint Sprayer?
I have been shopping online for a paint sprayer. I have found several different options. I typically paint less than 300 gallons per year.
I am leaning towards the Graco Magnum XR7. But I am also interested in the Titan xt290 I am open to other suggestions, but I am leading towards one of the two above. Anybody used one of those makes or models? Last edited by JCapshaw; 08-07-2009 at 04:08 PM. |
#2 |
I have a 6 year old titan 440-i that has never treated me wrong. in the first three years of having it i put about 3,000 gallons through it and the past 3 years about 40 gallons per year. it still runs like a champ.
the newer ones can be programed for fine finish spray or production spraying. meaning the fine finish setting keeps the pressure more constant for trim work but the pump works much harder. production setting the pressure fluctuates a little more. |
| The Following User Says Thank You to NAV For This Useful Post: | hammerheart14 (06-24-2011) |
#3 |
6 Years...wow, thats a long time. I have heard the titans tend to last a while.
#4 |
I don;t know about the titan , but I have a ASM zip, a real entry level sprayer made by graco,
i give it death and it handles awesome,we pulled it apart one day and there is only about 3 moving parts in the whole thing. I have heard that wagners are really complicated and tempermental. |
#5 |
The newer ones can be programed for fine finish spray or production spraying. meaning the fine finish setting keeps the pressure more constant for trim work but the pump works much harder. production setting the pressure fluctuates a little more.I have a 6 year old titan 440-i that has never treated me wrong. in the first three years of having it i put about 3,000 gallons through it and the past 3 years about 40 gallons per year. it still runs like a champ.
__________________ Best Paint Sprayers Last edited by lancerohn; 06-23-2011 at 08:58 AM. |
#6 |
handpaintedbysteve.com
Hey Capshaw,
I’ve had both Graco and Titan sprayers. My first sprayer was a Graco my last was a Titan. Of the two companies I had the best experience with the Titans. I’ve had two Gracos’ and nine Titans. Seven of those were 660s (the 440 is Titans' replacement for the 660) . They’re good machines and won’t let you down when you need them. With that being said, spend a few more bucks and go with the Titan 440, it will be something you can pass on to your kids in your will.
Best of Luck Steve To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
Titans are just as good as graco or better at a much better price. if you are a diyer or a small time painter, go with the Titan XY290. If you are a professional painter, all you will ever need is a Titan 440! That will last forever AND if it doesn't, Titan has the best warranties in the market (four years.)
#8 | |
What is the best paint Sprayer?Quote:
#9 |
Why don't professional painters test all the high end DIY paint sprayers, and give their results in a forum. That way, we DIYers can get a professional painters opinion? I am talking at the Graco X7 or Titan XT290 level. Is that a possibility?
#10 |
Well it would cost a lot of money to test all of the paint sprayers.
You can also check out the Graco Magnum X5 or maybe even one the Wagner models. The GPM are pretty high which will probably work for your projects. Found this article which talks more about the best paint sprayers: http://deviceraters.com/top-3-paint-sprayers/ |
#11 |
I haven't tested them all but, I will comment on the ones I have tried.
1. My go to is an airless Graco x9 older model Has not let me down is probably 8 years old. Is really just a little bigger than the one you are looking at. If I'm not mistaken Graco=USA Titan=China 2. I have a Wagner sprayer I bought for spraying doors and trim. Had a lot of trouble with it spitting. Found out if you let the cup get over 1/2 empty they tend to do this. Keeping it full solved the problem, for the most part. Also easy to clean. 3. I bought a Graco 3900 paint station HVLP (at Lowes $150) does a nice job but real PITA to use and there is definitely a learning curve. Latex paint is too thick to be sprayed so it must be thinned. They give you a little cup and you have to time how long it takes for paint to run out of the cup and you have to keep thinning till it gets in the limits. There is a write up on this unit in either last months Family Handyman or this months issue. They make an HVLP conversion spray gun that I have not tried yet but want too. This is about all I can help you with on small sprayers. Hope it helps. |
| Tags |
equipment, paint sprayers, painting ![]() |
| Display Modes | |
| Flat over Semi-Gloss | dankreboot | Painting | 21 | 02-24-2013 08:46 PM |
| Dark over light...Do I need tinted primer? | melissaandkris | Painting | 17 | 09-09-2011 11:43 AM |
| semi gloss enamel vs eggshell enamel | NoExperience | Painting | 18 | 03-05-2009 05:57 AM |
| Flashing | NoExperience | Painting | 13 | 09-04-2008 06:56 AM |
| Semi gloss on Semi gloss | mattpricemn | Painting | 6 | 08-25-2008 08:18 PM |
