What Am I Doing Wrong? - Painting - DIY Chatroom Home Improvement Forum
Old 06-19-2009, 04:00 PM   #1
what am I doing wrong?
argh.. I just finished priming a 10x11x8' room (approx 500 sqft paintable area)... it took me 5 hours, and 2.5ga of Zinssers 123 primer. The room was previously painted a light off-white color, but we had the whole house retextured with a light orange peel... so I'm hoping this has something to do with it. They floated all the drywall, and then sprayed on the orange peel, and now I just finished priming a room.
Here is what I am doing in general:
- Using a 2.5" angle brush to cut in the all the wall/ceiling edges and closet/door trim
- The door trim and closet trim wasn't retextured, and it was previously painted with an oil-based paint, so I lightly sanded and primed all of the trim with the brush. The primer applied A LOT easier on the trim; again, I'm hoping it's because of the texturing
- Roll everywhere else with Wooster 1/2" roller cover. I immerse the roller completely in the primer bucket, then roll against the tracks a few times to event out hte paint, and then apply in a W pattern on the walls.
After all of that, I'm left with a half bucket of primer and wondering what I'm doing wrong...
jdhar is offline   Reply With Quote
Old 06-19-2009, 05:17 PM   #2
What do you mean?
What is the problem?
Old 06-19-2009, 05:46 PM   #3
Sorry if I didn't make it clear.. I have read everywhere that 1ga of primer should cover 4-500 sqft, and I am using double that.
Old 06-19-2009, 06:08 PM   #4
the Musigician
DangerMouse's Avatar
well it should....under IDEAL CONDITIONS, which you did not have.
not your fault.....
DM
Old 06-19-2009, 08:20 PM   #5
k, guess I thought newly textured walls was as ideal as it gets... guess I was wrong
One more question; is primer supposed to go on as evenly and smoothly as normal paint? I see tons of lines after the primer has dried... but I applied my two coats of BM Regal and it looks fine. Just wondering if I should expect the same even-ness with the primer..
Old 06-19-2009, 09:46 PM   #6
I generally see thru primer
Primers main objective (I think) is to make sure that the cover coat can stick to whatever is under the primer
Old 06-19-2009, 10:33 PM   #7
cool, thx guys
Old 06-19-2009, 11:35 PM   #8
Matthewt1970's Avatar
Rewards Points: 1,098
That primer is soaking in and sealing the surface. If you were to put a second coat of primer on then you would probably see the right square footage on coverage.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
replaced 3way toggle with rocker switch - what's wrong? ellabo Electrical 8 09-22-2008 04:16 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Replacing wrong color grout - 900 SF of tile Lonidier Flooring 5 07-17-2008 04:50 PM
