Wet Paint Roller Before Using - Painting - DIY Chatroom Home Improvement Forum
Old 06-02-2009, 04:03 AM   #1
Haste Makes Waste
Wet paint roller before using
Is it advisable to wet the roller sleeve prior to painting?
saggdevil is offline   Reply With Quote
Old 06-02-2009, 05:42 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
I don't but it cannot hurt.
chrisn is online now   Reply With Quote
Old 06-02-2009, 04:08 PM   #3
NAV
no, dont wet the roller. what purpose would that serve other than watering down your paint?
before you paint, take your masking tape and tape the entire roller up. pull off the tape and all of the loose fibers will pull off with the tape leaving your walls fuzzy free
Oh, and spend $5 on a roller. dont buy a piece of crap, they are not all the same.
NAV is offline   Reply With Quote
Old 06-02-2009, 09:03 PM   #4
100 Year Family Tradition
4ThGeneration's Avatar
Most paints are 70% water and 30% solids. It will not hurt to wet your roller with water as long as you spin it out to get rid of the excess water.
What I have used for a few years is the Purdy colossal. Larger core and holds more paint. It also has a very quick working period when going from a dry roller to paint on the wall. You have to buy the frame to go with it though.
4ThGeneration is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
