Weatherstripping Sticking To Paint - Painting - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 10:52 PM   #1
Rewards Points: 14
Weatherstripping Sticking to Paint
I recently installed weatherstripping (the kind with a vinyl bulb held in an aluminum channel screwed to the jamb) on a couple of painted wood doors. The doors were painted with good quality 100% acrylic latex semi-gloss paint, one 5 years ago and the other two weeks ago. In both cases, the vinyl stuck to the paint and actually pulled the paint off the door where there was contact. Anyone else ever have this problem or know of a solution other than going to another type of weatherstripping?
IdahoBob is offline   Reply With Quote
Old 10-23-2008, 08:03 PM   #2
Paint Store Dude
put some talcum powder or flower on the painted areas to eliminate some of the stickeyness
Chazbe is offline   Reply With Quote
Old 10-24-2008, 11:15 AM   #3
Rewards Points: 506
Specifically what "good quality 100% acrylic paint" did you use?
SirWired
sirwired is offline   Reply With Quote
Old 10-25-2008, 01:40 PM   #4
Rewards Points: 14
Sir Wired:
The most recent door was painted with Columbia Masterpiece. The door from 5 years ago was either Masterpiece or a similar Kelly-Moore Product.
Old 10-25-2008, 02:48 PM   #5
Quick fix for weather stripping
After you repaint the areas that were pulled away, and stuck to the weater strip. Allow to dry (with door cracked) for 4 to 6 hours. Then apply a thin coat of Vaseline on the edge of the door and the weather stripping. This will allow the true cure time to your paint, and it wont stick. Good Luck, Duane Foster @ Color Wheel Paints and Coatings.
Duane Foster is offline   Reply With Quote
Old 06-23-2010, 02:11 PM   #6
A door a day is all I ask
TheDoorGuy's Avatar
Weatherstrip sticks to paint
Hi There,
I know this is an old thread but thought I would stick my 2 cents in.
The problem is not so much that the paint is not dry but more that
the vinyl interacts with the latex paint. Doesn't matter how long
you wait...Vinyl bulb will stick to latex (but not oil based) paint.
Usually after weather warms up the problem occurs.
The thing to do is to buy the metal weatherstripping with optional
silicone bulb. Looks pretty much the same as the vinyl bulb but will
not stick to latex paint.
It will be a special order item...The on the shelf stuff is all going to be
vinyl. You local hardware store can probably special order from
Pemko or Columbia Aluminum products.
This will solve your sticking problem and as an added bonus, if properly
installed, will give you a better weather seal.
If you have more door questions please feel free to contact me through
my website at www.thedoorguy.com.
Best of luck with your project!
RC/DG
TheDoorGuy is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
