We Need Advice On Painting Proches - Painting - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 09:56 AM   #1
We need advice on painting proches
Our porches have been stained with an exterior porch stain that was applied about 5 years ago. The porches look bad now and we want to go to a paint. It will go the style of the house, and we are hoping that the porches will look cleaner. We want to apply the right steps and use the proper quality and type of paint. Any expert advise?
betty wilson is offline   Reply With Quote
Old 08-17-2011, 12:10 PM   #2
m1951mm's Avatar
It would be helpful for you to answer a couple of questions. Are you talking about the flooring or vertical surfaces? What products were used previously?
One thing to always remember about an exterior, after the next rain or wind storm it will look somewhat dirty again. If you are planning on hosing it down often to keep it CLEAN looking different products will withstand that type of, shall I say it, abuse better than others. Outside is outside and is not meant to be perfectly clean IMHO.
I am sure the EXTERIOR PROS will come in and give you some good advice.
m1951mm is offline   Reply With Quote
Old 08-17-2011, 06:43 PM   #3
Gymschu's Avatar
Rewards Points: 652
I don't like paint for porches. Why? Because the paint lays on the surface & with heavy foot traffic, peeling becomes a big, big issue. In addition, you now create a slippery surface unless you add some grip additive to the paint. If your stain has held up for five years is there any chance you might just want to freshen it up with a thorough cleaning and a recoat? This would be the least expensive option requiring far less prep work.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
jsheridan (08-17-2011)
Old 08-19-2011, 12:23 AM   #4
To start the painting of your porch, you have to choose a paint color. The paint color you should choose must blend on the existing color of your home exterior. Better make use of your very best judgment when it comes to choosing the paint color and try not to go over the top.
sassyconnie is offline   Reply With Quote
How to Prep. Basement Walls for Painting vcheez Building & Construction 37 08-12-2011 09:32 AM
Lots of advice needed - exterior painting. lazzlazz Painting 1 06-20-2011 07:56 PM
Painting Over New Apt - Need Advice stilllogicz Interior Decorating 4 04-12-2011 02:27 AM
Help. Need advice on cold and painting crisilee Painting 11 12-29-2010 08:15 AM
Newbie needs some painting advice bji Painting 8 12-26-2008 12:50 PM
