Wax Sticks For Filling Nail Holes? - Painting - DIY Chatroom Home Improvement Forum
Old 05-01-2013, 02:47 PM   #1
Rewards Points: 640
Wax sticks for filling nail holes?
This is more of a finishing question... didn't know where else to put it
Does anyone still make those wax sticks for filling nail holes in stained trim? Minwax use to sell them I think, in different shades that you could match to your trim... I can't find them anywhere anymore by themselves, only in packs of every color available.
they use to be like a crayon you could rub on the hole..
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 05-01-2013, 03:13 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
If you use wax- it will always repel any finish you put over it.
I know NO pro that would fill with wax. There is color putty that you can finish made for the job.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-01-2013, 03:20 PM   #3
Rewards Points: 640
well the smart "pros" that built our house sure did and now I'm trying to find something to match it to fix a problem around where it was used.... not to mention filled screw holes on our stair rail with it and it looks bad how they did it, was trying to make it look better... every screw they put into the rail was from the top so they are all where you can easily see them instead of trying to hide them.... ugh
would you use putty even when the trim is already stained, polyed and put up? if so what brands are out there that are good I can look into?
Old 05-01-2013, 03:24 PM   #4
You know they used wax? I've really only seen it as scratch touch up sticks.
Makes no sense to use wax.
As far as what is around- got to any paint store. they have it.
Old 05-01-2013, 03:25 PM   #5
Rewards Points: 640
I can 100% guarantee you it is wax
Old 05-01-2013, 07:22 PM   #6
HD still carries them.
Old 05-01-2013, 08:53 PM   #7
Rewards Points: 344
Sometimes I mix a little stain with wood filler. I think I even saw tinted wood filler.
tribe_fan is offline   Reply With Quote
Freestanding deck with water in the holes. HHHEEEELLLPPP bassheadjohn Concrete, Stone & Masonry 28 08-23-2012 09:19 PM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
route wire through poorly drilled holes in joists? bottlerockett Electrical 4 06-27-2012 09:28 AM
caulking of nail holes showing yellow thru paint DennyF Painting 16 02-13-2012 03:54 PM
regarding nail holes in hardwood stairs Pat Fox Flooring 1 06-07-2010 09:41 AM
