Wavy Roller - Painting - DIY Chatroom Home Improvement Forum
Old 04-07-2014, 11:57 AM   #1
retired guy
igneous's Avatar
Rewards Points: 135
wavy roller
I just finished a job using a pro mar 200 low sheen over a previously flat painted surface. I don't understand why the roller is "wobbly" or "wavy" as I bring it down the wall. It is fine going up. It is a relatively new roller cage, not a cheap one. I used it last week on another job and none of these issue. It's screwed tight onto the extension pole. The cover is tight on the cage, and even when I used it without the pole in a tight corner, the wavy action still occurred. It isn't a big problem, but it shouldn't be a problem at all. Any ideas? Thanks in advance.
igneous is offline   Reply With Quote
Old 04-07-2014, 12:03 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
Could be a flat spot on the nap. Try a new cover.
Jmayspaint is offline   Reply With Quote
Old 04-07-2014, 03:46 PM   #3
Gymschu's Avatar
Rewards Points: 662
Could also be a problem loading it up with paint. It's not unusual to get paint loaded up on one side and not so much on the other side. You really gotta lube that thing up so the paint is evenly distributed throughout the nap of the roller before taking it to the wall. I'm sure you know this info, but sometimes when we are in a hurry we forget.
It also could be that you're using too thick of a nap for a flat wall. 1/2 inch max for flat walls. Just a few thoughts.
Old 04-07-2014, 06:49 PM   #4
Rewards Points: 5,974
New roller cover should solve the problem. Could be you didn't get all the paint out from the last job laid it on it's side and the paint dried leaving a flat spot.
Old 04-07-2014, 07:03 PM   #5
Rob
Robpo's Avatar
Rewards Points: 826
I am not a painter nor do I like to paint but it sounds like the roller is not turning freely. Maybe a glob of paint between the moving parts. You could also where dark sunglasses and stand farther from the wall.
Robpo is offline   Reply With Quote
What am I Doing Wrong Here (Roller Marks, pics) dimswits Painting 13 08-01-2016 05:33 AM
Painting Technique Help RichardZ Painting 5 01-31-2013 05:12 PM
Wet Edge on Walls: How Far Per Roller Load? Twister Painting 10 11-23-2011 04:28 AM
Exterior Painting-Brush or Roller? Smokin Gun Painting 8 07-12-2011 04:02 AM
Flashing --> how does it occur and how to prevent it gramps416 Painting 5 05-26-2010 11:11 PM
