Old 06-15-2012, 02:21 PM   #1
Post
waterproofing waferboard
How can you paint waferboard to make it waterproof in direct exposure to the environment?
And what do the "exposure" numbers mean?
johnhait is offline   Reply With Quote
Old 06-15-2012, 09:29 PM   #2
OK what do you mean by wafer board?
OSB, Partical board?
Both were never made to be left exposed.
Old 06-15-2012, 11:36 PM   #3
I'm aware it wasn't "made" to be exposed. The question is "What's the cheapest way to waterproof it?" Basement, or driveway sealant?
Old 06-16-2012, 06:33 AM   #4
Where is it?
Wall, ceiling, under ground?
Any pictures?
Old 06-19-2012, 07:37 AM   #5
Hi johnhait,
I put together a portable storage building whose siding was all particle or wafer board. It came in a kit and the board was already primed. I usually use Color Place semi-gloss latex paint on my house and I put it on the storage building also. That was about 10 years ago and it has held up well. If your wood hasn`t been primed yet of course you should do this first. I use KILZ primer. It is pretty thick for primer I think. See what you think and you can thin it down if you like so that it will flow easier into the seams made by the wood chips when they were pressed together.
MorknMindy is offline   Reply With Quote
Old 06-19-2012, 12:26 PM   #6
As waferboard is basically pressed material, there is no means to waterproof it. This material can be primed and painted for protection, but it will require periodic reapplication and maintenance.
Will22 is offline   Reply With Quote
Tags
waferboard
Stone Basement Waterproofing / Foundation Footings? troyce1 Concrete, Stone & Masonry 1 02-26-2012 11:11 PM
Conditioned Crawl Space - Advice re Waterproofing AND Int or ext insulation JohnNe Building & Construction 4 02-10-2012 07:53 AM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Stucco repair on the wall and waterproofing - some questions ohman Building & Construction 2 07-02-2009 01:58 AM
