Waterproofing Exterior Brick - Painting - DIY Chatroom Home Improvement Forum
Old 07-02-2009, 12:14 PM   #1
waterproofing exterior brick
Im looking for brick water proofing that has penetrating SILOYANE in it. Can anybody help or subject a good brick water proofing ?
upchuck is offline   Reply With Quote
Old 07-02-2009, 12:26 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by upchuck View Post
Im looking for brick water proofing that has penetrating SILOYANE in it. .....
If you are referring to Siloxane:
http://www.askthebuilder.com/B368_Si...Sealants.shtml
I have not used it. but others on this forum may
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-03-2009, 11:31 AM   #3
Rewards Points: 252
I am also assuming you are referring to Siloxane. Anytime I have used Siloxane I have purchased it as a clear sealer - I'm not familiar with a paint that has Siloxane as a component - then again there is a LOT of stuff out there I am not familiar with. Siloxane sealers are pretty easy to work with. They are pretty thin and easy to spread - not really any different than working with any other masonry sealer. Exactly what are you looking to do? Are you getting water seeping through brick? Above grade, below grade?? Do you want to paint it a solid color? Have you looked at products like Thorocoat and/or Thorolastic? Not sure where you are located but Insl-x (Which is a division of Ben Moore) does make Siloxane - runs @ $40 a gallon and any Ben Moore store should be able to get it for you.
Hope that helps some
mazzonetv is offline   Reply With Quote
Stucco repair on the wall and waterproofing - some questions ohman Building & Construction 2 07-02-2009 01:58 AM
Options for waterproofing cement shed floor YNOTDIY Flooring 4 01-19-2008 11:31 PM
