Waterproof Back Of Smartside Siding? - Painting - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 10:15 AM   #1
pwa
waterproof back of smartside siding?
Hi to all, I am putting lp smartside siding on a garage thats fairly protected from the weather in Idaho. It going over sheathing with tyvek on it but any water inturusion has me wondering if the backside should be primed and painted or waterproofed somehow.I cant find any info on how to treat the back? Thanks for any advice
pwa is offline   Reply With Quote
Old 07-07-2012, 10:20 AM   #2
Rewards Points: 13,300
Only place I would seal it is along any cuts, the bottom edge, and a few inches up from the bottom edge on the back side.
Installed correctly there should never be water on the back side, but sealing the bottom will help prevent back splash damage.
Just a guess, are you installing this because the buildings to close to the ground and the old siding it rotting out?
Old 07-07-2012, 12:38 PM   #3
pwa
No, this is new consturction.The water issues just scare me a lot.I have installed aluminum soffit and noticed most times a piece of trim is used to cover the flange of the J channel then the siding with a 3/16 gap for caulk and exspantion
Old 07-07-2012, 04:31 PM   #4
One good reason to always build the roof with an over hang, make sure there's Z moulding over the top of the window. Adding gutters also helps a great deal with the splashing and the run off.
If your going with Smart Side why are you using J moulding around doors or windows?
Old 07-07-2012, 06:32 PM   #5
pwa
The J channel is only in the eve's where the soffit is installed. I will have to get z flash for over the doors and windows(did'nt know about that one yet) and I do have gutters.
Old 07-20-2012, 04:45 PM   #6
Rewards Points: 12
Glad to hear you selected LP SmartSide for your project. I recommend that you contact LP customer care at 888.820.0325 to address your specific question about waterproofing. And I’ll check to see if we have any information that addresses this specific situation. Thanks, Pat
LPSmartSide is offline   Reply With Quote
Old 07-27-2012, 08:15 PM   #7
Rewards Points: 12
pwa,
Some in the industry may perceive back priming as performance enhancement but it isnít necessary for LP SmartSide siding and trim. In addition to qualification by an independent 3rd party, our successful internal testing of LP SmartSide siding in Hilo, Hawaii, (>170 inches of rain annually) consists entirely of siding without back priming. Thank you, Patrick
The Following User Says Thank You to LPSmartSide For This Useful Post:
Gymschu (07-28-2012)
Aluminum siding not matching after Door install alcopaulic Building & Construction 1 09-07-2011 09:46 PM
Do We Need to Redo Siding? HomeownerGal Building & Construction 9 09-02-2011 08:32 PM
vinyl Siding / Soffit Question J S Machine Building & Construction 42 04-18-2011 11:11 PM
LP Smartside Lap Siding - Nailing Question? canyonbc Carpentry 3 01-18-2010 02:26 PM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
