Waterbourne Enamel? - Painting - DIY Chatroom Home Improvement Forum
Old 12-10-2010, 10:23 PM   #1
Waterbourne enamel?
If I paint raw pine planks (#2 grade) with SW ProClassic and BM Impervo) how long will it take to dry before I can use it for bookshelves and not have the problem of the books sticking?
Should I use a primer first and, if so which primer?
Thanks!
marliz is offline   Reply With Quote
Old 12-11-2010, 05:03 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 470
Oil based primer first and at least a couple days to dry hard. The finish paint will take a month to fully cure but I have put books back on them after a couplr days with no problem.
Old 12-11-2010, 09:51 PM   #3
Thanks for the response. Would you use a good acrylic paint? Satin or glossy? It would help to know how long it takes for that to cure, though I know it would vary according to conditions.
Old 12-12-2010, 12:20 AM   #4
chrisn's Avatar
Rewards Points: 470
This is what I use,still, give it 2 or3 days,longer is better.
Old 12-12-2010, 07:54 AM   #5
A hundred thank yous. (One for each shelf I have to paint.)
Old 12-12-2010, 11:41 AM   #6
chrisn's Avatar
Rewards Points: 470
You're most welcome, glad to help.
Tags
bookshelves , pine , primer , waterbourne enamel
Tiny Bubbles in High-gloss Enamel Finish Heartbreak Painting 10 01-08-2012 07:27 PM
Sanding oil based enamel between coats. user85116 Painting 0 07-25-2010 10:38 PM
Poly over WB enamel over sanding sealer? bobmg Painting 3 05-10-2010 07:59 PM
Acrylic vs enamel artz Painting 9 10-27-2009 04:44 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
