Water Stains - Painting - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 09:21 AM   #1
water stains
What can I use to cover up water stains on walls
ogatica0921 is offline   Reply With Quote
Old 02-28-2012, 10:11 AM   #2
Rewards Points: 150
Kilz sealer
CaptRandy is offline   Reply With Quote
Old 02-28-2012, 10:17 AM   #3
Rewards Points: 14,312
First figure out why there's stains.
I'd use Zinzeer 123 instead of any Kilnz product. There to watery and take more coats.
Old 02-28-2012, 10:23 AM   #4
Mr. Paint's Avatar
If the stain is dry and there is no further source, the best is either Zinsser Cover Stain or BIN shellac-based primer/sealer. Water-based primers may re-activate any extractives. The products I mentioned are available in aerosol cans, quarts, ones or fives. depending on how big a job you have.
Mr. Paint is offline   Reply With Quote
The Following User Says Thank You to Mr. Paint For This Useful Post:
ltd (02-28-2012)
Old 02-28-2012, 01:13 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
This. Sorry Joe, 123 does not work well on water stains, nor does most any latex primer.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following 3 Users Say Thank You to Matthewt1970 For This Useful Post:
jsheridan (02-28-2012), ltd (02-28-2012), Workaholic (02-28-2012)
Old 02-28-2012, 03:25 PM   #6
I second the use of Zinsser Cover Stain, an aerosol can is probably your best bet for small stuff.
The Following User Says Thank You to jsheridan For This Useful Post:
ltd (02-28-2012)
Old 02-28-2012, 03:31 PM   #7
Workaholic's Avatar
Rewards Points: 268
I agree with both of these posts.
Sean
Workaholic is offline   Reply With Quote
The Following User Says Thank You to Workaholic For This Useful Post:
ltd (02-28-2012)
Old 02-28-2012, 04:22 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 622
wrong again
The Following User Says Thank You to chrisn For This Useful Post:
ltd (02-28-2012)
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
