Water Stain On Ceiling..how To Go Away?? - Painting - DIY Chatroom Home Improvement Forum
Old 09-20-2007, 12:16 PM   #1
Water Stain on ceiling..how to go away??
I had a small roof leak that caused a couple of stains on the ceiling. Both are approx 12" x 4 inches. Their sort of brown looking, you all know what I'm talking about! Is there anything that they can be covered with that won't stand out? They are in a very visible place in the ceiling and I certainly don't want to paint the entire ceiling. I'm sure you painters have to have some kind of trick to hide these ugly things......right?
thanks
Eric_ht is offline   Reply With Quote
Old 09-20-2007, 02:27 PM   #2
Remodeler
MinConst's Avatar
You can use a sealer made especially for this. Spray can sprays up. If the ceiling is fairly freshly painted and white it may hide. You would need to seal these areas even you do paint the whole ceiling.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 09-20-2007, 03:48 PM   #3
Pro Painter
kils, binz, zinser coverstain are all spray can primers that will seal in the stain. You may be able to find a spray can designed to spray straight up or just use a regular one.
Best to find the paint the ceiling was painted with originally or at least find the information and buy that paint. It's the only way to spot paint it so it won't stand out too much.
Reality is that it will stand out somewhat, though.
joewho is offline   Reply With Quote
Old 09-20-2007, 04:26 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
To do it right we seal the stain then paint the whole ceiling
There's an ever so slight chance it won't look too horrible just touching it up
But that would be pretty rare
slickshift is offline   Reply With Quote
Old 09-20-2007, 04:33 PM   #5
Workaholic's Avatar
Rewards Points: 268
I agree.
If your ceiling is white then i would try kilz upshot.
Sean
Workaholic is offline   Reply With Quote
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Water lines on sloped ceiling (pics attached) Mr. Michael Roofing/Siding 8 03-27-2007 02:13 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-28-2005 11:05 PM
