Water Stain - Painting - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 09:52 AM   #1
water stain
I had a shower leak down to my basement and the ceiling which is some sheet rock and some drop down tiles are stained.
The paint looks to be flat latex. Will KILZ do the trick and will water based cover the stains?
wtcamb is offline   Reply With Quote
Old 01-27-2009, 10:34 AM   #2
(the original)
Rewards Points: 756
No, you need oil or shellac on water stains. The oil based original Kilz would probably do OK for you, but my first choice is Zinsser Cover Stain. If it's a small area, you can even buy it in spray cans.
ratherbefishin' is offline   Reply With Quote
Old 01-27-2009, 04:11 PM   #3
Rewards Points: 506
Any oil-base primer should seal those stains just fine. (Water-base primer will not seal stains caused by water itself.) Note that the primer probably won't hide the stains, but it will keep them from bleeding through whatever topcoat you apply.
SirWired
sirwired is offline   Reply With Quote
Old 01-27-2009, 04:32 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
You'll need a solvent-based stain blocker (oil/alkyd/shellac/alcohol)
Original Kilz (oil-based) should do the trick
slickshift is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 01:11 PM
