Water On Oil Based? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 09:02 AM   #16
cdaniels's Avatar
Guess I'm just old fashioned.It would be a nightmare for me to have to come back to a customer's house and strip a peeling door (or several doors) and start over.Yes sanding is definitely essential.Thanks for the info guys- never too old to learn.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 03-24-2013, 09:19 AM   #17
Rubbin walls since'79
Brushjockey's Avatar
While I almost always sand and use a primer, here is an example of one that would probably work fine straight on with prep-
So almost all absolutes usually have some exceptions, and with the tech changing so quickly in paints and the completion is fierce to get an edge, this will only increase.
http://www.muralo.net/products/ultra_7657.php
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-24-2013, 09:53 AM   #18
That looks like a nice product BJ, unfortunately have no Muralo dealers in this area. Coronado, a BM company, has a medium grade semi gloss, RustCat, that bonds like crazy. There are a couple of bonding finishes out there.
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
