Water Based Stain Over Oil Based? - Painting - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 09:50 PM   #1
Rewards Points: 152
Water based stain over oil based?
Stripped down the deck a couple years ago, have been applying a coat of the same oil based semi-transparent stain annually. Went to get a gallon this year and the paint store no longer makes/stocks oil based stain.
Instead offered the water based or waterborne stain and said it'll perform the same and will go right over top of the existing oil based. Is that right? Stripping the deck of the old solid stain a few years ago took a LONG time and don't want to have to do it again....
burnt03 is offline   Reply With Quote
Old 05-05-2013, 09:58 PM   #2
Jmayspaint's Avatar
Rewards Points: 536
If the old stain is worn enough to allow penetration of the new, it might be alright.
Most stains are designed to penetrate and won't do well sitting on top of an existing material. As you probably know since you had to strip once already.
Jmayspaint is offline   Reply With Quote
Old 05-06-2013, 04:15 AM   #3
Too Short? Cut it Again!
You should be alright. The trend is away from oil-based products because of environmental concerns, etc.
A waterbased product may raise or check the grain more than oil-based but your older deck surface may be beyond that being a major factor.
Horrid wax based products like Thompson's Water Seal can cause all kinds of problems and obviously for waterbased stains. Don't use anything like them that promises to make water bead. If there is such a product on the deck you will have to strip it as best you can like you would a waxed interior floor.
Old 05-06-2013, 07:24 AM   #4
Rewards Points: 394
Many exterior stain products are hybrids (oil/acrylic), which allows the adhesion to be very good, in addition to complying with VOC laws so the products can be actually sold. The products are also soap and water clean up (at least when they are wet), which is convenient.
Will22 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
