Water Based Enamel - Painting - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 11:03 PM   #1
Rewards Points: 260
Water based enamel
I need to paint some wooden planter boxes. They will not be exposed to the elements on a daily basis. I am looking for a gloss finish. I could only find semi gloss paint in acrylic/latex. I found some high gloss enamel for interior/exterior. It is water based. What is the difference between enamel and a regular latex based exterior paint? Does it dry to form a hard shell? I don't want the boxes to look like plastic.
bluefitness is offline   Reply With Quote
Old 04-04-2011, 11:13 PM   #2
Except for true flats, all interior/exterior sheen finishes are enamels. You can also get flat enamels, for washable environs. Enamels are more of a film forming finish with higher protective value, higher sheen=higher protection. High gloss exterior grade enamel is what you want.
Old 04-05-2011, 08:25 PM   #3
Rewards Points: 260
I purchased some Valspar high gloss enamel for around $25. Sherwin Williams is having a 40 percent off sale this weekend. I was thinking about returning the paint (wasn't tinted) and buying a gallon of Duration paint. What are your thoughts on this?
Old 04-06-2011, 06:04 AM   #4
I think that would be a better deal. Just a thought, are these boxes lined or coated on the inside? Damp soil inside may wick through and damage the painted surface.
Old 04-06-2011, 09:47 AM   #5
Rewards Points: 260
Yes, there will be a plastic liner. Thanks again for the help.
Old 04-06-2011, 06:37 PM   #6
Faron79's Avatar
Rewards Points: 260
Yeah, the word "Enamel" used to imply "hard, glossy finishes" when Oil paints were first advertised. They were borrowing the idea from the hard "Enamel" layer on your teeth.
When Latexes started out, they too were called "Enamels".
Bottom line:
The term itself has NO meaning relative to paint-type or quality.
It WAS and always shall be...."A marketing buzzword"!
Faron
Faron79 is offline   Reply With Quote
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
