Water Base Poly Over Oil Base Poly - Painting - DIY Chatroom Home Improvement Forum
Old 08-23-2007, 10:32 PM   #1
Question
water base poly over oil base poly
I have knotty pine in my home on the walls. It has one coat of oil base clear on it, and it is still a little rough. My ? is, would it be all right if I did a light sanding and put on water base poly on it? Drying time is an issue because I have a dog in the house. Thanks
pappabear is offline   Reply With Quote
Old 08-24-2007, 08:30 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
Is that why you want to switch to water based?
slickshift is offline   Reply With Quote
Old 08-24-2007, 11:24 AM   #3
Yes,because of shorter drying time. Will water based poly work over oil base poly?
Old 08-24-2007, 02:53 PM   #4
slickshift's Avatar
Not that I'm aware of
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
water base over oil base csvharvest Painting 6 03-01-2007 07:12 PM
water based or oil based poly? J187 Flooring 3 09-03-2006 07:42 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
