Water Base Over Oil Base - Painting - DIY Chatroom Home Improvement Forum
Old 02-12-2007, 04:39 PM   #1
Question
water base over oil base
as rule water based paint can never go over oil base paint?
csvharvest is offline   Reply With Quote
Old 02-12-2007, 05:40 PM   #2
From what I have learned by painting my front door without thinking about it being oil based that was on it, you should use a particular kind of primer that allows you to go over the oil based paint with latex. If you don't, it seems it will not adhere properly and you end up with the new paint peeling off.
my5cats is offline   Reply With Quote
Old 02-12-2007, 07:05 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You should also properly prep. the surface to be painted.
One way is to sand the oil painted surface to a 'dull' finish.
Use an oil-based primer that is suitable for such an application. After drying, apply your quality latex paint...
- Build Well -
Old 02-12-2007, 07:17 PM   #4
thanks for anwsers
Old 02-12-2007, 11:12 PM   #5
Pro Painter
NO, it's the other way around. Never go with oil over latex. But that rule is very old, going back to the homes primed with linseed oil primer and painted with latex.
With today's fomulas you can do just about anything.
In the case of the door where the paint is peeling, it's not due to the oil based paint itself. It's due to covering a gloss that hasn't been primed or sanded. That can happen with any paint, be it oil or latex.
joewho is offline   Reply With Quote
Old 02-13-2007, 07:30 AM   #6
Thanks Joe!
Old 03-01-2007, 06:12 PM   #7
Every situation is different ,I can easily go with a flat oil over a high gloss latex without any adhesion problems.I can also go over oil with SOME latex paints ,There are exceptions to every rule but basically dont put latex over oil without extensive sanding or the proper primer(there are both latex and oil primers suitable for this)
torpainter is offline   Reply With Quote
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 03:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 01:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
