Old 05-17-2010, 04:13 PM   #1
want to paint a fridge water line
I just bought a fridge, but i need to run a small 3/8 diameter water line for the water/ice dispenser for the fridge. Im gonna run the water line on the floor. I want to camoflauge the line with the cabinets.
My cabinets are stained a cherry red. I just wanted to know what kind of paint i should use to paint the water line(spray paint,latex,acrylic)? Would a primer be required also?
humberguy is offline   Reply With Quote
Old 05-17-2010, 06:39 PM   #2
i'd use something like Krylon Fusion, no primer necessary. it's specifically for plastic/pvc.
noboru wataya is offline   Reply With Quote
Old 05-17-2010, 09:39 PM   #3
thanks for the response.
Old 05-17-2010, 10:47 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Fusion spray would work
I'd also think a gel stain would work, and might get a closer look to your cabinets
slickshift is offline   Reply With Quote
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
