Walls Unpaintable??? Help, The BLACK - Painting - DIY Chatroom Home Improvement Forum
Old 09-05-2010, 10:31 PM   #1
Rewards Points: 12
Walls Unpaintable??? Help, the BLACK
Okay, so the previous owner of my house got screwed by a contractor. The contractor put the black tar used to coat a foundation on the outside to prevent moisture on the INSIDE of the foundation, making 40% (75% of that room) of my basement walls in one room PITCH BLACK.
I mean, it's kinda shiny, but at night I walk down to my workshop and think someone trapped their goth child in the basement and said "do what you want kid". Or it looks like a shrine for secret virgin sacrifices. It's scary as hell to because there's no lights on that end. Picture attached, it's my basement.
Seriously, help, how do I paint my black tar cement walls
jamieofansa is offline   Reply With Quote
Old 09-05-2010, 11:42 PM   #2
Rewards Points: 150
use bin shellac primer on it. seals back anything.
hammerheart14 is offline   Reply With Quote
Old 09-06-2010, 07:56 AM   #3
Where are you located ?
I'd be inclined to build an insulated wall in front of it
Old 09-07-2010, 05:55 AM   #4
I will second this statement........................
mark942 is offline   Reply With Quote
Old 09-07-2010, 08:03 AM   #5
Rewards Points: 79
If the contractor only sealed that one side, it may be important that you do as little as possible to disturb that sealant. As with all projects though it comes down to what you - or "the boss" wants. So - if the texture is ok and the wall is water tight, you can prime it as suggested with the Zinsser primer. Check with your "knowledgable" paint store man on the base to use though. Shellac or oil are both very good and stick to anything - as well, anything sticks to them. FYI the oil base is the best to use on pressure treated lumber although the shellac is best on the knots.
jackofmany is offline   Reply With Quote
Old 09-10-2010, 07:52 PM   #6
liscenced electrician
Rewards Points: 538
are the walls just cement/cinder blocks right now. If so, i would also built 2x4 walls insulate and sheetrock.
jimmy21 is offline   Reply With Quote
Old 09-10-2010, 08:54 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
Hang some white bedsheets infront of the walls.
Old 09-12-2010, 11:45 PM   #8
I would make it my darkroom. (photographer)
JerMann is offline   Reply With Quote
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Insulate/air seal shared walls in townhome? RebornRenov Building & Construction 4 01-07-2010 09:50 AM
How do I clear up black mold on plaster walls? frustratedtnant General DIY Discussions 6 08-14-2009 03:56 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
black shadows/stains on walls gaylew44 Building & Construction 16 09-30-2008 05:01 AM
