Walls With Black Spraypaint.... - Painting - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 10:35 PM   #1
walls with black spraypaint....
im a rookie.
my apartment kitchen has white walls, and in some parts there is black spray paint graffitti on some parts and i want to do something about it.
can i get away with just painting over it, or will i need to sand the old paint off? what are my options?
Stratto711 is offline   Reply With Quote
Old 12-14-2012, 10:43 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Shouldn't be a big problem. The only issue is adhesion. If you give the sprayed areas a light quick sand to give the paint something to adhere to, you should be good.
You might want to hit the dark stuff with a coat or two to get it covered before finishing the whole wall.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-14-2012, 11:26 PM   #3
Great, thanks for the tip.
Old 12-14-2012, 11:42 PM   #4
Rewards Points: 12,830
Going to have to prime it first with a sealing primer.
Old 12-15-2012, 12:39 AM   #5
Rewards Points: 6,652
Depending on what color you are painting the walls, Zinser Primer can be tinted to a tint close to what you are going to paint the walls. Only need to sand down rough spots that are from previous fixes.
Old 12-15-2012, 09:42 AM   #6
Gymschu's Avatar
Rewards Points: 218
If I found graffiti on my walls, I would move.
Gymschu is online now   Reply With Quote
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
Jay 78 (12-16-2012), jsheridan (12-15-2012)
Old 12-15-2012, 11:32 AM   #7
A lot of times it is done by tenants being evicted, or they let their kids run rampant and do this stuff. One place I lived at for about a year, one tenant was teaching his kid knife throwing, and trashed about every wall in the unit.
Does not mean because of one bad thing or apple, that everyone should leave that building or complex.
Old 12-15-2012, 06:00 PM   #8
Are you sure?
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
Walls Unpaintable??? Help, the BLACK jamieofansa Painting 7 09-13-2010 12:45 AM
How do I clear up black mold on plaster walls? frustratedtnant General DIY Discussions 6 08-14-2009 04:56 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
black shadows/stains on walls gaylew44 Building & Construction 16 09-30-2008 06:01 AM
