Wallpaper Removal And Lead Paint Risk? - Painting - DIY Chatroom Home Improvement Forum
Old 05-22-2008, 11:50 AM   #1
Wallpaper removal and lead paint risk?
My husband and I just bought a house and are trying to do some work before we move in. The walls of nne of the bedrooms and the hallway are covered in wallpaper that was then painted over. We'd like to remove the paint and wallpaper so that we can start with a fresh coat of paint.
The house was built in 1927, so we're a little concerned about lead paint.
What are the risks involved in removing paint covered wallpaper that may or may not have been put on top of lead paint?
Is this something we can do ourselves?
If so, what precautions should we take?
Thanks!!
rhena is offline   Reply With Quote
Old 05-23-2008, 04:37 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
I would think as long as you keep the project wet so as not to create dust,you should be fine.
http://www.wallpaperinstaller.com/wa...stripping.html
Old 05-23-2008, 07:01 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Keep it wet to minimize the dust. Wear some disposable coveralls and a dust mask with P100 filters. Use a shop vac with a HEPA filter to collect any dust. You could test it first. Most paint stores will be able to help you out with that. Paint made before WW2 commonly had lead in it. Less and less after that.
Old 05-23-2008, 07:03 AM   #4
Rewards Points: 506
You have two issues here:
1) You likely have lead paint on your walls. The rules, laws, and regulations for dealing with lead paint vary from state to state. Consult your local Health Department for details. If you screw it up and do not follow the required procedures, you may have a very difficult time selling the house in the future. DO NOT just rely on the advice of any old schmuck on the internet (including us) telling you what is allowed or not allowed in your jurisdiction.
2) You have painted over wallpaper. This makes the wallpaper MUCH more difficult to remove. It would likely be difficult or impossible to remove without getting little paint flakes everywhere. It may be easier just to put on a coat of special wallpaper meant to act solely as a backing for a paint job.
I would go with the special paper, as you will then not have to lose sleep about contaminating your house with paint removal debris. This assumes that this method of paint encapsulation is approved for use in your area.
SirWired
sirwired is offline   Reply With Quote
Old 05-24-2008, 05:26 AM   #5
chrisn's Avatar
Rewards Points: 394
Read and listen to what Sirwired said.
Old 05-23-2009, 10:32 AM   #6
I am also buying a house with wall paper.
my husband wanted to put sheet rock over the wallpaper instead of taking it down or painting over it. is that a good idea or should we take down the wallpaper? and if we should take down the wall paper how do we do that.
gig7984 is offline   Reply With Quote
Old 05-24-2009, 05:01 AM   #7
chrisn's Avatar
Rewards Points: 394
Removal of wall paper is NOT that difficult. Why in the world would you consider putting up new drywall( expense) when removal is so easy? There was a link posted for removal procedures. Here is another. If you do not want to do it call a paper hanger who will, MUCH cheaper than installing new drywall.
http://www.safeandsimple.com/
http://www.sbbolson.com/other_hangers.htm
Remove the paper, it is easy!!
Old 05-24-2009, 06:49 AM   #8
The most important question that no one has asked yet is, do you have kids? If you do, you need to really be careful because lead affects them in ways that it won't affect an adult. Taping off the area and using negative pressure is a necessity. I would also wear tyvek suits and remove all clothing and place into the washer after each day of work. Lead is nothing to play around with.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 05-24-2009, 07:15 AM   #9
Haste Makes Waste
SirWired
SirWired: What is the special paper you refer to? I have areas in my home such as above and getting ready to re-do those rooms. I do not want to have to remove all this paper or it might be 2010 before I get paint on the walls.
saggdevil is offline   Reply With Quote
Old 05-24-2009, 08:20 AM   #10
Matthewt1970's Avatar
Rewards Points: 1,098
Get one of the little test kits from the paint store before you start going through hopps. They are so simple to use. You just rub the little marker like tip on the surface, and on a spot you scraped to the bottom layer, and if it turns pink, you have lead.
Old 06-11-2009, 08:36 PM   #11
Haste Makes Waste
So if the outer visible painted surface is known latex, will the lead pen still work. It would have to read through 96 years worth of paint and paper. I know for sure the last layer of paint is SW latex.
I removed 96 yrs worth of painted paper in one room and it came off easily (shock) but time consuming. Days of scraping the dry stuff (came off easily cuz it was so thick), then wet and scrape off the backing/glue. Then scrub and repair wall.
Old 06-12-2009, 09:53 AM   #12
Just make sure you scrape a spot down to the bottom layer to test and that will react to any of the layers.
Old 06-07-2011, 04:30 PM   #13
New product out since this question was asked
I know the question is a couple of years old now, but since it was first asked, the EPA has come out with new rules that require professional rennovators, home owners and remodelers to test for the presence of lead paint in any home built before 1978.
The old -fashioned "swab" tests mentioned above are no good on drywall and plaster and they can take hours to give an accurate result. But there's a new test I got at Home Depot called "D-Lead Paint Test Kit" that's easy to use, accurate and fast.
Doing a quick test for lead can keep you from spending hours and hundreds of bucks tearing out paint when you don't really need to. Or, it can quickly alert you that the job you're undertaking is more than a DIY should attempt on your own.
Try the D-Lead kit before you do anything else. At least then you'll know what you're up against.
papa00hMowMow is offline   Reply With Quote
Tags
lead paint , wallpaper
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
OLD Paint Removal on Interior Doors water_cutter101 Painting 14 05-10-2008 09:46 PM
lead paint - remove or cover? teresa17603 Painting 8 10-26-2006 06:14 PM
