Wallpaper Removal - Painting - DIY Chatroom Home Improvement Forum
Old 06-10-2009, 08:47 PM   #1
Haste Makes Waste
Wallpaper Removal
Chris....Help!! The Safe & Simple IS NOT removing the painted over paper over the mantle. I've scored it several times, wetted several times and attempted to scrap. Only a few scraps of paint came off about size of a quarter. What do I do next? Actually all the other areas....the paper backing/glue came off easier with my homemade solution . I'm writing this Wednesday night as I know you'll be back from vacating tomorrow. Hope you had a good time and had one for me.
saggdevil is offline   Reply With Quote
Old 06-11-2009, 04:44 AM   #2
Remodeling Contractor
you may need to use a steamer to remove this.
Old 06-11-2009, 06:41 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
Try this,HOT, water, lots of it, apply a sheet of painters plastic over area to hold in moisture, let it soak for 15 minutes.
Old 06-11-2009, 10:12 AM   #4
100 Year Family Tradition
4ThGeneration's Avatar
Some paper guys who I networked with said sometimes you can not remove it without damage to the walls underneath...
4ThGeneration is offline   Reply With Quote
Old 06-11-2009, 10:28 AM   #5
Haste Makes Waste
That's what I'm afraid of. It's a 2ft x 5ft section over a solid oak mantle/fireplace. It's strange....all the plaster walls are white, but this 2x5 section is gray but is just as smooth as the white. You can feel no physical difference where the two colors join. But I think possible they failed to prime this section prior to paper installation. All the other is coming off rather easily other than the time and labor, lol, since it's 10-12ft high and a very large room. Ah....and so many more to go, lol .
Got a feeling I'm just gonna have to spred mud on it and try to smooth it out. Most of this area will be covered by a large mirror. Only about 2" in each side is visible.
Old 06-11-2009, 10:35 AM   #6
when you do paint over it use a oil based primer. Water based primers will cause trouble normally with bubbling, but the funny thing is that your wanting it off anhyow. I do not want to be the one who suggest to coat it with some latex paint and watch what happens, but...
Old 06-11-2009, 12:39 PM   #7
Haste Makes Waste
I'm gonna coat that 2x5 area with Kilz Original..... I am gonna use Guardz on all the walls in this room as ChrisN advised. So I guess Guardz first, then Kilz Orig on this area then paint. I'm pretty frustrated with this job. It was bad enough to have to strip 96 years of this nasty crap...now an area I can't even clean up. All I can figure is the PO's for past 96 years have been very lazy to let this crap pile up and just keep painting over it. Such a shame with large rooms, tall ceilings and beautiful wood to have all this crap on the walls. Sorry for the "b" session, just getting tired. This is room 5 and each one has had a different set of problems, lol. Oh well...hopefully all this hard work will pay off. The goal is to see beautiful painted plastered walls. Sure is tough getting there, lol.
Thank you for your advice and Chris as well. I'd probably already have jumped off the bridge at this point.
Old 06-11-2009, 12:46 PM   #8
I am not a wall paper guru, but have removed a lot in my days, one thing stands out now. That place is old. I hope you wore a Nosha approved mask at the least. No telling what chems and such went into that products back then. Hate to wake up with an extra ear or something...
Old 06-11-2009, 01:08 PM   #9
Haste Makes Waste
No, actually I did not wear a mask or respirator. The thick painted over paper sheared off in strips using a putty knife (I do less damage with it vs a paper scraper) with very little flaking and virtually no dust (amazing since I'm not the greatest housekeeper, lol). In the other rooms, I did wear a mask when sanding. I had to do a lot of wall repair and three of those walls were "painted over paper". I used mud and sanded. However, I used 123 primer (water based) so I hope I don't get bubbles, lol. If so, those three walls need stripped anyway. I've getting a little more brave and confident as I finish each room, lol. Hopefully by the time I make it upstairs, I'll be a pro.
Wallpaper Removal Choices in Kitchen LeviDIY Painting 14 12-02-2011 03:30 AM
Wallpaper removal and lead paint risk? rhena Painting 12 06-07-2011 04:30 PM
Wallpaper Removal saggdevil Painting 1 06-01-2009 04:31 AM
Wallpaper removal diylady Painting 10 10-01-2008 07:23 PM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 05:41 PM
