Wallpaper On Plywood - 30 Yrs Old - Paint Or Paper - Painting - DIY Chatroom Home Improvement Forum
Old 02-22-2013, 09:04 PM   #1
Wallpaper on Plywood - 30 yrs old - paint or paper
Similar to previous post, I have vinyl wallpaper on plywood that has been there for 30 years (some less). Would painted plywood really look any better than painted wallpaper? Some of it has satin grain finish that I wouldn't mind coming through with the paint. Others is more porous. I've also read to "score" it to break integrity. Wouldn't that show through?
joeybl is offline   Reply With Quote
Old 02-23-2013, 03:01 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
I do not know what you are asking.
Is painted wall paper better that painted plywood?
Old 02-23-2013, 05:10 AM   #3
Rewards Points: 77
I'd use a nice layer of BIN primer to seal the wallpaper from the paint, then paint over. You won't have any issues painting over the BIN with a latex
Justins1171 is offline   Reply With Quote
Old 02-23-2013, 08:24 AM   #4
Rewards Points: 6,034
OK I'm a little confused also but here goes. You don't say what kind of room this is so I am going to assume it's a room that gets quite a bit of use.
As far as removing wall paper that has been up for 30 years the word nightmare comes to mind. Then to do anything with the plywood allthe paste (did you catch that Chris) has to be removed. Then the seams will have to be dealt with as in filled. And it's hard to paint plywood with out the grain showing thru.
As much as I don't like painted wallpaper it may be a better option. You don't say if the wallpaper is colored or has a pattern, if either I would prime with Cover Stain. It is oil based so be ready for the odor and the hassle of clean-up. But if you use a water based primer the water can loosen the paper. BIN would probably work but in this situation I would use the oil.
The 3rd option is remove all of it, update your insulation and wiring(if it needs it) and put up sheet rock.
The Following User Says Thank You to ToolSeeker For This Useful Post:
chrisn (02-23-2013)
Old 02-23-2013, 04:54 PM   #5
chrisn's Avatar
Rewards Points: 614
Certainly cover stain as opposed to Bin, if , for some reason it cannot be removed.
The Following User Says Thank You to chrisn For This Useful Post:
ToolSeeker (02-23-2013)
Old 02-23-2013, 08:50 PM   #6
cdaniels's Avatar
Is this in a house? Never seen plywood walls in anything but a shed or barn.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Gymschu (02-23-2013)
Lead Paint and Wallpaper followingwords Painting 6 06-10-2013 08:24 AM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 03:40 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Sizing vs. matching paint for wallpaper alvanos Painting 2 05-22-2006 05:27 PM
